My apartment honeywell a/c is on full crank at 90 degrees on "heat". It doesn't feel warm at all, though it's been on for hours. I have a new filter in, as well. Also, "fan" and "auto" are other controls on this honeywell a/c unit, I'm not certain for sure what that means in detail and how it can save me money.
  • 334 Answers
The "Fan on/auto" switch is desighned to give you the option of running the fan constantly, which continuosly filters the air in gives circulation.
It does not effect the heat or cool modes of the unit. All it does is effect the fan.
On the "Auto" setting, the fan will only come on when the unit is calling for heat, or cooling.
This will save a little bit of electricity, but will not continuosly circulate or filter the air.
What was the temperature inside tha apartment when you first set the T-stat on 90?
What is it now? if it is still climbing and it started out very low, it may just be working fine.
If not, you could have other problems, like low refridgerant (if it's a heat pump) or bad insulation on a very cold night or an undersized unit.
Has it been working properly before or have you just moved in/turned it on?
Posted on Dec 06, 2008
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Heater not blowing enough heat
Check the thermostat and the water pump.
Feb 20, 2015 | 2004 Cadillac CTS
What is the on/off temperature (heat) range for a RTH111 series
Heat range: 40 to 90 degrees F
Cool range: 50 to 99 degrees F
1 degree deadband
Here's the operation guide:
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2603EF.pdf
Please mark my answer as helpful.
Jan 05, 2015 | Honeywell Digital Manual Heat/Cool...
My central heating does not go very warm
There is an over temperature thermostate in the heating system and it is most likely defective.
Dennis
Oct 31, 2012 | Honeywell Programmable Thermostat Heater
Have a honeywell thermostat t6575b1003 and my a/c unit wont get below 90, is this a thermostat issue?
Does it feel like 90 where the thermostat is located? If it's not hot in that location, then your thermostat is most likely going bad as far as the temp. goes. If the A/C isn't cutting off, then the thermostat doesn't know what the temp is to cut off. I would suggest replacing it if you have these symptoms. If it feels 90, you need to have the unit A/C unit checked out.
Jun 13, 2011 | Honeywell Heat/Cool Thermostat
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
Cooling Problems
Your filter is clogged. Not the one at the bottom of the unit.The one above the unit. It is like a raditor coils, kind of a bear to get to. We have cats and dogs the filter gets most of the hair but not all.Usualy about 6 bolts to take out.The proublem will be at the bottom of the top filter.
May 09, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
161 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
