A black box is covering half of screen
I pressed the wrong combination of controls and the menu button and a black box appeared on the screen blocking the tv screen
  • 106 Answers
Look in the menu for the "captions" heading. Once in the closed captions, turn off the "text" heading. This text mode is putting up the black box on the tv
Posted on Dec 06, 2008
A black rectangle appears in the bottom half of the screen. The rest of the picture is fine, the sound is fine. The box goes away if i press the menu button - but it comes back again. What is wrong?
Do you have a cable/satellite box connected to this tv?
Try this first it sounds like you have the closed caption turned on by accident.
On the remote press the MENU button.
Use the navigation keys to move the selector to CC and press OK.
This should bring up the Closed Caption sub menu.
Ensure that the closed caption is set to OFF
Thanks,
Robert
Feb 26, 2011 | Vizio M220VA 22 in. LCD HDTV
A black square appears on certain channels on my tv and i cant get it to go away. the box is huge and it blocks most of the video.
It Captioning 1,2,3 and Text 1,2,3 still on functioning.Check ur remote have a CC button press that button turn off all the Captioning like 1,2,3.Go into the menu look for captioning turn it all off,all the captioning like CC1,2,3 and Text 1,2,3 all to off.These black boxes,will not appear again in the middle of the screen.
Oct 28, 2010 | Hitachi 46W500 46 in. TV/DVD Combo
Sony Wega 27in Randomly Has Block Box Appear On Screen
this means the TV having picture upper part of the screen. problem may be -15 V to vertical deflection ic suddenly gose off and system control gose to stand-by mode resolder vertical out ic , -15 v supply line from the fly back and system control .
Jan 15, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Black box in middle of screen
Note that the large black box goes away when pushing buttons on the tv (ex: the black box will disappear to show the volume setting when changing the volume on the tv but it will cover the picture and the menu display of the dtv box).
This is caused by the closed caption setting of the television set NOT the captioning of the converter box. To fix this you must open your television's menu, find the ccd/closed caption option, and turn it off. This is a frustrating problem as when most people are told to shut off the captioning they try to do so at the box.
Normal dtv box captioning will appear as a small text box at the bottom of the screen as you would expect - not as a giant black rectangle that covers most of the screen. If you do want to shut this off too you will find that you can't do it through the usual menu options (the menu will only allow changes to font, color etc.) - there should be a ccd button on the remote that when pushed will scroll through ccd-1, ccd-2,... off.
Dec 01, 2008 | Toshiba MV13L2 13 in. TV/VCR Combo
Black Box appearing on my screen
unplug the set for a while , but this problem will return because of a malfunction in the EPROM CHIP , this controls the menu and a few other functions
Oct 17, 2008 | Philips Magnavox 27MS343S 27" TV
Black box covering one-half of TV screen
Try turning off the text box function of the closed captioning.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Problem with black box appearing on tv screen
Check to see if close caption is enabled, on remote, press menu, see if there is setting.
Jul 26, 2008 | Televison & Video
Rectangular Black Box Covers Lower Half of the Screen
I found this because I"m having the EXACT same problem with my DVD. Very frustrating that nothing works....
Feb 10, 2008 | Sony DAV-C450 System
A black box appears on the screen
Just happened to see your black box problem associated with your T.V.; Thought I would pass along an idea for you to check into, and let me know if it helped...Check into whether or not it has a onscreen text block mode, if it gets into this mode by accidentally pressing the wrong buttons on the remote and or TV, it could and I have seen, at least with zeniths, a big black box which will cover the whole screen except for a 2 to 4 inch border around the box and outer edge of the screen...if this is the case, find someone familiar with the correct setting for the set associated with this problem, and get it back into the right mode....Hope this helps..T.
Jan 15, 2008 | Haier 20" TV/DVD Combo
Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
Dec 02, 2007 | Philips PM435S Remote Control
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
