Question about Goodman CLQ36AR49 Air Conditioner
Will not go into defrost
I installed a goodman 2 ton heat pump 2 months ago. heat and cool mode works fine but will not go into defrost. installed a new defrost board today still does not work. checked voltage at the condencer and air handler the thermostat wires have at least 24 volts at each wire . what could be the problem? thanks Tim
  • 1 more comment
  • adamatim Dec 06, 2008
    thermostat has not been changed . checked all the wires and are correct.
    the board was brand new today,more than likely it is not bad. if all the wires are correct on the thermostat , what else could it be ? by the way, thanks for the reply's
    got ya. thanks i'll check that tomorrow, i didn't even think of that. any good suggestions about how to check it ?
  • 85 Answers
Did you change the thermostat in heat pump? or did you change it when you replaced the board?
Posted on Dec 06, 2008
  • 1 more comment
  • Armando Bernal Dec 06, 2008
    Your thermostat inside the house may have to be reconfigured, or if defrost is directed by the unit, then identify which pin timer to use and change the setting on your heatpumps temp to kick on. The only thing that could keep the defrost from comming on would be the thermostat that plugs into defrost board, or the board itself being faulty. Those pumps can be a pain..
    Never mind the board or the wires, I'm talking about the thermostat in the heat pump, connected to the defrost board, and cliped to one the of the units coils. That may have failed.. And no problem about the reply's, I just wish I was there with you, I would fix it right away.
    Yes, pull it off and replace it! Hope this fixes it. Usually board comes with new therm, make sure you didn't throw it way with box. Get with your supplier and see if they normally come with them, or just buy it it's not expensive. And double check your defrost wire from unit to furnace/airhandler, sometimes it looks like it's connected correctly, pay attention to schematics.
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Where can I find the specs for an earlier Goodman heat pump?
You say 2 to 3 years... I'm assuming the unit is older than that. Especially being r22. What about the first 10 years??? Normally you will get 400 to 500 sqft per ton of cooling, but, that depends on heat load calculations. If the unit wasn't big enough you would have had this issue 10 years ago, not when the system kept running low on refrigerant. At first guess I would say a 2 ton unit is not big enough but if it worked fine for 10 years...wuth all that in mind, if it were me, (a seasoned professional) I would spend 1800 to fix my 15 year old r22 unit before I spent $4000 on a new r410a piece of junk. Best Wishes!!
Jun 29, 2017 | Goodman GMS90703BXA Heater
Goodman heat pump model gph1442h41aa will not turn on
first confirm that the condensing unit outside is getting power or even a command to come on .check function of thermostat your t-stat may command heat in the cooling mode.instead of the heat mode, being a heating system generated by a cooling condensor. also check bateries in t-stat. make sure breker in the panel box is on ,it is a double breaker usualy marked with an amp rating of 20 ,or a 30 on it . also check disconnect switch located next to your outdoor condensor usualy a gray box on wall of building. make sure its on or diconnect tab is pluged in . hope this was helpful. good luck.
Feb 11, 2013 | Goodman GPH1524M41 2 Ton 15 SEER...
Can not get Goodman 3-ton heat pump out of heat mode and into cooling mode
The reversing valve may be stuck. It allows the unit to switch between heating and cooling. You may be able to give it a tap but only on one of the ends, not the sides, and only lightly. You could also unplug the reversing valve from the circuit board. Some reversing valves are energized in heat mode some in A/C mode. When you unplug it, if it shifts, you will hear a loud hiss as the valve shifts and the pressure equalizes.
May 04, 2010 | Goodman CLQ36AR49 Air Conditioner
Normal in cool cycle, very high pressure in heat cycle
Expansion valve on the condensor or possibly overcharged with refrigerant?
Nov 01, 2009 | Goodman Heating & Cooling
Fan not running on Heat Pum
That does not sound normal at all, I have a Goodman Heatpump and the Fan on the Evaporator (outside unit) should run as soon as it starts up!
The only delay you should be seeing is when the unit starts, the fan in the AHU starts 5 seconds after and runs for about 1.5 minutes after shutdown.
Sep 19, 2009 | Goodman CLQ36AR49 Air Conditioner
We live in SC, have a Goodman 4 ton split system w
First of all is this unit a heat pump i'm not up on goodman model #'s if it is a heat pump reversing valves do go not a real common problem 1000.00 is excessive i would be inclined to get a 2nd opinion. plastic over the sand could create a condensation mold problem. Good luck. Tom
Jun 23, 2009 | Goodman CLQ36AR49 Air Conditioner
New Goodman condenser unit run almost contiously using too much e
I'm not sure of the kilowatts. The 10 min on and 5 off is telling me there is to much heat by the thermostat or you house needs more insulation. The new compressor is designed for more efficient run time. The other thing is the unit to big for your house? It should run 10 -15 min when low humidity is in the house. Otherwise longer if its pretty warm inside.
Jun 11, 2009 | Goodman Heating & Cooling
Goodman heats but defrosts turns on before desired temp.
Yes. The defrost cycle of a heat pump is actually turning on your airconditioning to heat up the condenser to thaw it out. During this cycle your electric strip heaters "should" be adequate enough to compensate for the a/c being on. At about 30 - 34 degrees outdoor temp there is not enough heat in the air to to adequately heat your home with the heat pump only. Some technitions will use an outdoor thermostat to turn off the heat pump when it is under 34 degrees outside. If you are to cold when its under 34 degrees intall more electric strip heaters.. But if you do this your electric bill may go up significantly.
Welcome to the wonderful world of electric heat pumps (lol).
Good luck.
Mar 29, 2009 | Goodman GMS90703BXA Heater
On My goodman heat pump, It had blown the transformer, I installed a 3amp fuse and when engaged into cool mode blows the fuse. I have narrowed it down to the yellow wire in the heat pump that goes to the...
That low pressure switch is isolated so that would not be the issue. The defrost board is the most likely culprit but you did not post the model number to tell more
Jan 31, 2018 | Goodman Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
516 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
