Question about Brother HL 1440 Laser Printer
Alarm light stays on
Unit does not print. Performed reset, still does not work, toner cartridge appears to be full
  • Anonymous May 16, 2008
    Printer worked fine until internet got hooked up. Now it won't print at all. Need help! Am afraid to do anything as software and manuals were destroyed in Hurricane Ivan.
  • Anonymous Mar 18, 2014
    Alarm light is on and will not print
I had a similar problem, but my alarm light was "only" blinking. here is what i did (and might work with your printer too): open the front and take out the drum&toner unit. take out the toner cartridge und put a little piece of paper in the hole (the one you can look right through to the other side) either at the right or left side of the cartridge. put the toner in the drum unit and then everything back in the printer. after that my printer worked and still works fine.
Posted on Aug 24, 2007
  • peter Hansen Jun 15, 2013
    Thanks, it worked for me. Why is it that the printer has to decide if there is tone or not.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
Data and alarm lights stay on,won't print
The Toner cartridge is empty, You can possibly take out the toner and tilt it fron side to side and maybe get a few more prints, but most likely you will need to replace the toner.
Mar 06, 2011 | Brother HL 1440 Laser Printer
My samsung 315 clp has status LED red light on.
It is a color laser printer.it has 4 toner cartridge(1)black(2)magenta(3)cyan(4)yellow all cartridge is missing or toner finished.Please purchase full set toner.All toner cartridge has a image sensor.When toner is run out then it is out of work.
Dec 14, 2009 | Samsung CLP 315 Laser Printer
Ready light doesn't stay lit, alarm light is red
Because I was getting gray shading on my pages and data was still being printing, I decided to change the toner cartridge. Now the pages are clean and white and all the lights function properly. Most cartridges that are running on empty don't print any data at all or at least print the data at the top of the page and gradually gets fainter sp? on the page. Who would have thought just by changing the cartridge would solve the problem? So glad that's all it was........wasn't excited about having to buy a new printer.
Jul 22, 2009 | Brother HL 1440 Laser Printer
Muratec mfx 1600 drum replaced alarm will not reset
Ignoring the Toner Empty Message
When the toner cartridge is empty, the machine shows a “Toner Empty”
message and stops printing.
You can set the machine to ignore the message when it displays and to
continue printing the pages.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button (�� or ��) until “Ignore Toner” appears on the
bottom line and press Enter.
3 Press the Scroll button (�� or ��) to select “On” or “Off.”
Select “On” to ignore the Toner Empty message.
Select “Off” to stop printing when the message appears. This is the
default setting.
4 Press Enter to save the selection.
Jun 18, 2009 | Muratec F320 Plain Paper LED Fax
Brother HL-2040 toner light stays on
I found this and it worked great.
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Mar 17, 2009 | Brother HL 5250DN Laser Printer
Copier won't print after refilling toner cartridge
As far as I know, filling up with toner is not enough. There is an electronic chip that must also be replaced, so the toner cartridge tells the unit it is a new one. Check with your supplier for such chip.
Oct 14, 2008 | Sharp AL 1631 Copier
Alarm light only, doesn't print at all
Chances are that you have a piece of paper stuck in the printer. Open the rear door and check there first. If that's not it, remove the toner/drum assembly and check behind that. The other place to check is between the drum unit and the toner cartridge.
Sep 14, 2008 | Brother HL 1440 Laser Printer
Brothers HL 1240 Alarm light on
Pull the drum out the front door, remove the toner cartridge and check for any paper and remove it.
Make sure there is toner in the toner cartridge. Look at the lights on the printer. Look at the labels beside them. The label "Toner" will have two lines going to two lights. If those two lights are on when you try to print, you are out of toner. But a now toner and install it in the drum. Install the drum back into the printer.
If not, look at the drum. At the rear top is an opening across the whole drum. Look inside it, you will see a metal grid. That grid must be clean or it will cause small sparks. These sparks will cause a false toner empty error. Buy a can of compressed air from Best Buy (or wherever). Use this compressed air to blow clean the grid. Move the small blue tab at one side of the opening ti the other side and back again. Reinstall the drum and try printing again.
If neither of those help, write back and let me know what lights stay on when the printer stops.
Sep 06, 2008 | Brother HL 1240 Printer
Brother HL 1440 Laser Printer Logo
448 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
