Back to:
Tags:
Hnn NABC NABC LMR NIMH BATTERY MOTO HNN9009H EQUIV.  2-Way Radio
Why do I get continuity between the whip portion...
By Ross - usenet poster
Why do I get continuity between the whip portion and the center of my CB antenna, and between the whip and shield portion, but not between the center and the shield?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 08, 2005
Not Rated (0)
Bomber
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Typically the capacitance of the cable will increase the resistance between the center conductor and shield of the cable, and the antenna will generally have a coupling capacitor prior to the connection to the cable. But between the whip portion and the center, there was continuity and there was continuity also between the whip and shield portion. The DC resistance of any antenna is not the same as the total impedance of that antenna. All DMM's measure only the DC resistance and not the total impedance of any item.
For example, measure the resistance of any "8 Ohm" antenna with a DMM. The resulting measurement will vary, generally as between 3-6 Ohm. This is only showing the "DC" component of the total impedance.
The antenna will radiate the signal properly and not burnout the transceiver as long as the SWR (Standing Wave Ratio) remains between 1.0 and 2.5. The antenna can work as long as the impedance at the desired frequency remains 50 W and the SWR remains between 1.0 and 2.5. Once again, the measurement is only accurate for DC (0 Hz). Antennas are tuned for operation within certain band limits. The impedance can only be tested at that frequency or band of frequencies.
There are other components in the manufacture of an antenna. Internally, the antenna will have a combination of components to help tune the antenna to the proper wavelength and power rating. Some antennas utilize inductors and capacitors, others use resistors and capacitors, still others may combine one or all of these in the design of the antenna. These "tuning circuits" can be a combination of LC, LR, RC, or even LRC (L = inductor, R = resistor, C = capacitor). The most common is an inductor or coil, sometimes referred to as a "loading" or "base" coil. The resistance of almost any coil will measure less than 10 W at DC or 0 Hz.
These concepts can be studied further via reference books such as the ARRL handbook and/or ARRL Antenna book.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Why do I get continuity between the whip portion and the center of my CB antenna, and between the ....:
I don't want to Accept this solution
Can you Help with these 2 Way Radios problems?
2 Way Radios
I need a Dummies guide on how to operate these. I've read...
2 Way Radios
where can I get a copy download or buy
2 Way Radios
i havr a i425 motorola nextel and i had a boost chip in...
2 Way Radios
This gps stopped working about a week ago. I was traveling...
2 Way Radios
I have a rather old Marconi 2951 radio test set which I...
Loading problems.
Repair Service
Find 2 Way Radio Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
