REMOVAL
(1) Remove quarter trim panel.
(2) Remove the bolts attaching the latch to the cab
side panel.
(3) Remove the nuts attaching the frame/hinge to
the B-pillar.
(4) Remove the glass from the cab.
(5) If necessary, remove the latch from the glass.
INSTALLATION
(1) If removed, install the latch to the glass.
(2) Center the window glass at the opening, insert
the hinge studs in the B-pillar holes, and install the
nuts.
(3) Attach the latch to the rear side panel with the
bolts. Tighten the bolts with the latch in the lock
position and pushing rearward on the latch.
(4) Test the vent window for water leaks.
(5) Install quarter trim panel.
INSTALLATION
nuts.
