Question about Mag Innovision 19" LCD Flat-Panel Monitor LT916S
My flat screen was going in and out for awhile, now it is completely black, but the blue power light is on. From what I have read it sound like a capacitor on the invertor board may be the culprit, but there are several. Whats the best way to test them and can it be done with an ohmmeter?
Thanks!
You can test capacitors with an ohmmeter. A good capacitor behaves like a short circuit when you first apply a voltage, then its resistance increases as it charges. The capacitors that fail are electrolytic types with polarity, so be sure to put the meter ground lead on the capacitor negative. The cap will be marked. An open capacitor will show no kick in the reading, and a shorted cap will show a constant low resistance.
Now, having said all that, ohming a capacitor isn't 100% effective as a test. A capacitor's value may change to the point where a circuit will stop working, but if the cap isn't shorted or completely open, or is just a very low value, the ohmmeter test won't show a problem. A capacitance tester is better. Many digital meters include a capacitance test function.
Most inverter circuits have only a small number of capacitors, and it's usually faster just to change them all. If you replace a capacitor, keep the capacitance the same (the microfarad value) but use a little higher voltage rating. Caps come in standard voltage values, and they get physically larger as the rating increases, but if you just go up one level the new part will usually fit. The main reason these go bad is that the manufacturer used too low a voltage to begin with. It keeps costs down, but the parts are stressed and often can't deal with it.
Posted on Dec 06, 2008
Jun 12, 2014 | HP Computers & Internet
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Dec 04, 2009 | Samsung SyncMaster 932B LCD Monitor
Nov 05, 2009 | LG Flatron L1515S 15" LCD Monitor
Sep 25, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Jun 16, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Feb 26, 2009 | Liquid Video L17LCD2 17" Flat Panel LCD...
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Aug 05, 2008 | HP f1905 19" Flat Panel LCD Monitor
Aug 18, 2014 | Mag Innovision 19" LCD Flat-Panel Monitor...
Oct 25, 2010 | Mag Innovision 19" LCD Flat-Panel Monitor...
281 people viewed this question
You are the Best. I did what you suggested today and bought 3 220uf caps that were rated 35v, up from 25. They were the ones closest to the spot on the board that looked as if it was getting overheated and seemed reasonable to start with those. I just plugged it in and works like a charm. Thanks again, I hope this post helps others.
