Have a Dell laptop, about 4 years old, try to start it up, goes to the Windows XP Pro screen then to a blue screen stating that the computer must be started in one of the startup options listed, however absolutely none work. I've tried last setting which worked, etc, still the same screen. Any suggestions? Thanks for your help!
    Master:
  • 474 Answers
Are you talking about it going to the windows start up options and it give you like 30 seconds and then restarts all over again.
Its known as the windows boot loop.
If this is it, i know exactly how to help you, but i dont want to type the method up unless this is the case, just respond and let me know and i will give you the fix.
alos, it requires you XP Disk or the disk that came with it, any XP disk will do.
let me know, thanks
Posted on Dec 06, 2008
  • 837 Answers
In those list of options is an option like
"Disable automatic restart on system failure"
Select that and then boot the laptop .. it should reboot and stop at an error screen
Let me know what it says
HP Stop code CRITICAL PROCESS DIED how do I sort this out
NO COMPUTER STATED of the 1000 made in 36 years.
or 1984 to now HP.
no OS stated, of 14 by Microsoft, or linux, or freedos or OS/2
wow only the word DIED is clear.
no screen photo's presented.
The process is complex, after all its computer not a toaster.
3billtion transistors at least there.
that's billion with a B.
my guess, (par for here)
is OLD HP PC< like 20 years old>
running what, XP? the virus magnet and loves to BSOD>?
my guess is windows, BSODs with a blue screen of *****
as even GILL BATES did on stage long ago?
top reasons are
1: bad power, if laptop take out the big battery.
2: bad RAM. try them 1 by 1. to find which one is bad. if have 2 easy
3: XP is corrupted, as all are, or will soon be, read the news lately?
XP is now Dead for 3 years, and is a virus magnet.
VISTA was shut down this spring.
4: bad video card or its driver bad is super common way to get BSOD.
5: loading PC chip drivers not for you old PC, = BSOD.
BSOD the blue screen if *****, that millions get ?
Aug 17, 2017 | HP Computers & Internet
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
My 13 year old son laptop need be reset like new
There are a couple possible solutions to your problem. If the computer will still turn on and load windows, and I assume you are using Windows XP, you can try doing a system restore. To do this, go to Start, Programs, Accessories, System Tools, and select System Restore. If system restore is enabled, you should be able to choose a date in the past when the laptop was working properly and restore the computer to that date. If you want to completely reload windows, you will need a Windows XP installation disc. Load the disc in the CD or DVD player and reboot the computer. You should see a screen asking you to press any key to boot from CD, go ahead and press Enter. You will now enter setup where you can reformat the hard drive and reload windows XP. Follow the on-screen instructions to delete any old partitions, and then create a new partition and format it using NTFS. The windows XP installation will continue after the hard drive is formatted. If, when you reboot the computer with the installation disc in the drive, you are not prompted to boot from CD, you may need to reboot and press F2 or F12 to change the boot selection to the CD or DVD drive so it will load the CD first before it tries to load your original Windows installation.
Jul 18, 2010 | Dell Inspiron 1525 Laptop Midnight Blue
Laptop wont start windows xp pro. goes to a blue
Take one memory stick out and test. Then do the other. Also checking each memory slot.
If not solved. When the computer starts, continually press F8 until you get startup menu- select SAFE MODE and fix the driver or software that is in startup
or
Roll back to last known configuration that worked.
While you are there- disable Auto Reboot on Failure.
May 02, 2010 | Computers & Internet
No keyboard windows sign in
it sounds as if your windows xp pro has not been activated. reload with the proper code or phone microsoft on number stated on activate windows.
hope this helps.
Apr 27, 2010 | Dell Precision 360 Workstation/Personal...
Dell Inspiron 6000 about 3 years old. When I boot up, sometimes it goes through the early Windows XP screens and then goes to a blank screen. It indicates that activity is going on but cannot see it on the...
The screen cable is most likely damaged. Try connecting an external monitor. If it works, you need to take the computer to a repair center to have the cable changed.
Aug 24, 2009 | Dell Computers & Internet
Laptop comes on. Writing comes up to start stating -start up windows safe mode ect or choose this one etc I do that and once I enter password it goes and says welcome and then a blue screen
G'day trex440,
Sounds like you've got a corrupt windows.
Laptop brand model?
What version of windows are you running. eg xp home xp pro vista etc.?
Try a chkdsk command first via your windows disc.
boot from your windows disc for now.
Cheers
pcfixit
May 06, 2009 | Computers & Internet
O/S does not work
Go to safe mode and do a system restore to a date before you started downloading songs
Jan 07, 2009 | Computers & Internet
Restore windows 2000 like-new state
check if have backed up your system state before installing things on windows 2000. then you can restore the system state then delete all the program's folders by hand
Jul 06, 2008 | Microsoft Windows 2000 Professional for PC
Blue Screen
Likely a driver issue.
http://support.microsoft.com/kb/314063
Boot to the safe mode, run a system restore to before the problem, see if it is resolved. A lot of the time, issues like this are caused by a combination for old drivers and new windows updates.
Jun 23, 2008 | Dell Inspiron 8600 Notebook
Computers & Internet Logo
332 people viewed this question
David Payne
David Payne
