? 1:40
https://www.youtube.com/watch?v=GKH-p6u0O8Y
Mar 26, 2014 - Uploaded by MyFinlux
Stay in control of your TV viewing thanks to our PVR functionality. You can pause live TV, or even record shows up to seven days in advance via USB. ... SEG 46" 46125 FullHD Smart TV Uydu Al?c?l? Kanal Ge?i?i ve Media Player ve ... Terms · Privacy · Policy & Safety · Send feedback · Try something new!
? 13:54
https://www.youtube.com/watch?v=pqfAs2kBKHM
May 10, 2013 - Uploaded by TheSuperUberGOLDFISH
Finlux 32H6020-D 32 Inch LED Widescreen HD Ready TV with Freeview & USB PVR Recording Black (New For ... Gadget Show Live 2013: Finlux 47inch LED Smart TV with 3D, £799 - Duration: 2:17. by ShinyShiny 12,627 views ... Terms · Privacy · Policy & Safety · Send feedback · Try something new!
Add some details.. Make sure your AC adapter is working fine.. Normally it has a LED which shows it's giving output...... If that is working you have Dead Printer Motherboard issue.. Which can be fixed if you have proper gadgets.
The Paper Jam message may appear on the display if
the Brother machine is not feeding paper correctly, paper scraps stucked or the paper is not loaded properly in
the paper tray, the jam clear cover located in the back of the machine,
is not installed properly or the PE Actuator is missing or damaged.
Please visit the link provided below to resolve the issue step by step :
If it doesn't do this with paper in the tray, it's a stuck paper present sensor flag. If the machine thinks there's paper there, it tries to feed. Since paper doesn't make it to the timing sensor, it shows a jam. Check for a stuck flag above where the leading edge of paper would be with the cassette inserted.
E-3 Cause: If the Paper Output Tray is closed or not opened fully, open it fully. The machine resumes printing.
Solution: If opening the Paper Output Tray fully does not resolve the problem, the paper may be jammed. Remove the jammed paper, reload paper properly in the machine, and then press the Black or Color button. If it is still having a problem follow these steps to reset the device.
>>Issue: ERROR LED: E, 3 Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the <ON/OFF> button again.
3. Wait until the device has completed its cycling process before submitting another job request. >>If it still is not fixed after that your printer will have to be serviced.
You dont need side bar anymore, rightclick anywhere on desktop and goto
gadgets, Add the ones you want, put them where you want (side, top,
anywhere) and thats your gadgets as they were in vista.
If you have installed Windows 7 beta then you must
be aware of the bug that whenever UAC is switched off, Sidebar and
Gadgets in Vista fails to display properly on Windows 7 Desktop. Though
this is not for every machine but many users have reported this problem
that their Sidebar and Gadgets are not working properly.
For older beta
versions of Windows 7 there had been some temporary workarounds for the
same problem. But if you are using Win7 Build 7000.0.081212 then this
can be fixed using a simple registry hack which like in Vista will
Elevate your Sidebar and Gadgets Process. If you know how to
play with you registry Editor then just open regedit.exe
from Run command in Windows 7 and go to KEY HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows \CurrentVersion\Sidebar\Settings
From there edit the DWORD value of AllowElevatedProcess
and set it to 1. You don’t need to restart your
Windows 7 computer after this. If your sidebar and Gadgets were not
working properly earlier then they will be fixed instantly.
The scanner is not working properly, not the printer part of the unit.
The LED array is not lighting causing black scanned prints.
Resolder the contacts in the LED array...probaly a cold solder joint.
please have the check on fuser for damage. Could be a thermistor, thermo switch, or faulty heaters. To clear error, service morefunction/clear/error/ok/ exit service mode and cycle power.
fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
Fuser error codes cannot be reset by power cycling the machine eventhough that is what the display tells you to do. In order to reset thefuser error code you must enter the service mode & reset the code.To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** Afterclearing error stay at the machine to see if it comes to ready. Thefuser assy can reach 139 degrees C.(Water boils @ 100C) The error canonly be cleared through the service mode because a technician shouldinspect the fuser to verify there is nothing faulty that could possiblystart a fire. If you enter the service mode & clear the error,power cycle the machine & during warm up the machine throws a codeagain- turn it off, unplug it & call a tech for fuser repair. Good Luck!!
jiggle the tray until it registers the light off.
