Question about Canon LBP 800 Laser Printer
Paper jam cleared - but still won't work
LBP 800 had a paper jam which has been cleared by removing the cartridge and taking out the paper. The paper came out cleanly ( ie all in one piece) I have check everywhere for small paper bits or dust - and there is nothing in there. I've replace the cartridge, closed it & it just keeps telling me there is a paper jam. Normally it whirrs into action to start printing. I've tried turning it on and off, checked the printer cable, rebooted the computer - everything I can think of. Any suggestions?
Turn off the printer for a while then back on again, if it still refuse to print, try printing a test page.
Posted on May 23, 2007
SOURCE:
I had a cannon LBP2900 printer. IT has a problem of paper jam. It prints very well in A5 paper but hen i try to print in A4 paper, the paper gets jam. It also makes some cracking sound and i found some...
Without doing a complete disassemble, remove all covers, remove paper tray(s), remove ink cartridges (or laser cartridges...everything that is EASY to remove. Clean your rollers (may be gummed up a bit), remove all dust, dirt, grime, everything. My Canon printers are extremely sensitive to jams. As long as you keep it clean internally, you should have no problems. Take a look at this video about paper jams.
Nov 30, 2017 | Canon LASER SHOT LBP-2900 Printer
PAPER JAMMED IN CANON LBP 1210 WANA OPEN IT MANULAY & REMOVE PAPER AS NOT ABLE TO DO IT BY REMOVING CARTRIDGE
I think it is rolled with the fixing unit along with the teflan sheet.Remove the back cover and gently try to remove it otherwise remove the fixing unit and remove the paper. It it occurs oftem please change the fixing unit.
Feb 17, 2011 | Canon LASER SHOT LBP-3000 Printer
A paper has struck in printer so its not printing how to remove the paper
1) Open the top cover
2) Remove the toner cartridge
3) Remove any paper from the multipurpose tray
4) If you can see the LEADING EDGE of the jammed paper slowly pull it out.
This may be easiest from either the multipurpose tray side or from under the toner cartridge
5) If you can see the TRAIL EDGE of the jammed paper slowly push it through the printer until it comes out
Dec 17, 2010 | Canon LASER SHOT LBP-2900 Printer
How to fix paper jam! problem
Clear the paper jam Followthese steps in the order presented to clear the paper jam. Step one: Remove any loose paper: Remove any loose sheets of paper from the input tray and theoutput tray. Take note: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the jam from therear of the product Take note : Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product. 1. Pressthe Power button ( clip_image001.gif ) to turn off the product. 2. Disconnectthe USB cable from the rear of the product. 3. Disconnectthe power cord from the rear of the product. 4. Pressin the tab on the left side of the rear door to release the door. Remove thedoor by pulling it away from the HP All-in-One. Figure 1: Press the left side tab torelease the rear access door Gently remove any jammed paper orbits of torn paper from the rollers inside the product. Use both hands to pullout any whole sheets of paper to avoid tearing them. Take Note: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure2: Remove scraps of paper Replacethe rear access door. Gently push the door forward until it snaps into place. Step three: Clear the jam from theautomatic document feeder (ADF) 1. Openthe cover of the ADF. Figure 3: Open the cover of the ADF 1. Gentlypull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If you do not remove all the pieces of paper from the product, more paper jams are likely to occur. 2. Closethe cover of the ADF. Step four: Clear the jam from thefront of the product 1. Lookinside the product through the paper output tray to check if any loose or tornpaper is stuck in the rollers. 2. Gentlypull the paper out of the rollers. You must Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism. Use a flashlight to make sure that you find all traces of paper. 3. Reconnectthe power cord to the rear of the product. 4. Pressthe Power button (clip_image001.gif ) to turn on the product. Step five: Print a self-test report Printa self-test report. Please inform me if this help you with the paper jamproblem.
Nov 22, 2010 | HP J3680 Officejet All In One Printer
How do I remove stuck paper
Please follow these steps:
•1 Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
•2
Turn off the printer.
•3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
•4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
•5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
•6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
•7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
•8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
•9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Aug 18, 2010 | HP Officejet Pro L7680 All-In-One Printer
Hello sir, one paper is jam in cannon printer. how solve this problem??
Take out all the cartridges then you are able to remove the jammed paper.
May 25, 2010 | Canon LASER SHOT LBP-5000 Printer
My printer is 5 weeks old. My Samsung CLX 3175FN color laser printer has a paper jam. I have removed as much of the paper as possible, but it is still jammed ( where I cannot get at it ) in the upper rear...
Have you turned the printer off then tiurn it back on. If you have a paper jam, after you remove the paper, you must restart it for it to clear.
Otherwise, if there is paper still in the printer, turn off the printer remove all 4 toner cartridges and the waste cartridge. Once you do that you may be able to see the paper. You may be able to take one more thing out to where you can see the paper better, I am not sure.
Kevin
Jul 19, 2009 | Samsung CLX-3175FW Multifunction Laser...
Paper jam
just remove all cartridge and u will find the stell plate wich is movable from there u can remove the paper
Mar 25, 2009 | Canon LASER SHOT LBP-5000 Printer
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
LBP 800 Paper Jam
You need to check the two small paper sensor levers located inside the machine. One of them may be stuck, giving a false jam message.
First is located in the centre,towards the rear just after the paper input roller, the other is located near th front, just after the output of the fuser (Heated rollers)
Oct 02, 2007 | Canon LBP 800 Laser Printer
Canon LBP 800 Laser Printer Logo
510 people viewed this question
Clive
Clive
old marine
old marine
