Question about Frigidaire Kitchen Ranges
The Oven in my Frigidaire FGF326AS Gas Kitchen is not working, the ignition working just fine.
  • kevinbrook Dec 07, 2008
    Helpful, Thanks.
  • Ron Coons
    Ron Coons May 11, 2010
    your oven not lighting??? but you see the "GLOW BAR" glowing?? assume the tops light just fine
    Habit-Forming:
  • 171 Answers
Replace the oven ignator [ the GLOW BAR] it's not geting hot enught to ignite the burner. So it does not open the safty valve.
Posted on Dec 06, 2008
Oven gas flame is very small
You may have a bad igniter. If you have a glow bar igniter you may not be drawing enough amps to fully open the gas valve.
Feb 01, 2014 | Frigidaire FGF326AS Gas Kitchen Range
Problem with the Frigidaire FGF326AS Gas Kitchen Range will not ignite
A few of the more promising DIY guides to helping you fix your igniter problem:
www.applianceaid.com/gas.html
www.davesrepair.com/DIYhelp/DIYovenignitors.htm
www.appliancepartspros.com/repairtips/repairtips_range_oven.aspx
Dec 27, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Well all the burners turn on, but the oven doesnt turn on, i can see the glow when i turn the nob but it doesnt lite up, like if their is no gas their, i have a Frigidaire model: fgf326wgsf. tomorrow is...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Oven will not light-broiler works
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jul 26, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Top burners on Frigidaire gas stove come on but the oven will not.Whats the problem?
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 30, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Oven works sometimes
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Dec 03, 2009 | Frigidaire FGF326AS Gas Kitchen Range
Smell gas from inside oven. oven will not heat up. no leaks from gas line outside of oven
On the bottom of the oven on the inside you will find an igniting bar. It is rectangular and usually just has one or two screws in it. This is your problem, switch it out and it will work fine.
Aug 09, 2009 | Frigidaire FGF326AS Gas Kitchen Range
Oven won't light on low settings (170), no trace gas smell.
Igniting bar located on the inside of the oven it is a rectangular piece with one or two screws. It is basically a heating element that also controls the gas. Change that ignitor and it should fix it no problem.
May 03, 2009 | Frigidaire FGF326AS Gas Kitchen Range
No spark to top burners, oven & broil will not light
it sound's like the spark module you might be going in too deep
Nov 06, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Oven
In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. (It's the igniter that actually controls the gas valve) The igniter has probably gone bad. ($50.00 to $90.00 for igniter)
Jun 09, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Kitchen Ranges Logo
117 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
