GE Model wwsr3090t6aa Agitator problem
We just recently had a problem with are ge washer.the agitator stopped agitating and you smell like a burning belt smell when it try's for long enough,everything else works fine?
  • Anonymous Mar 28, 2014
    Agitator Stopped Working
  • 334 Answers
You probably have burning belt LOL.
Can you turn the agitator by hand at all?
If no, look for anything that may have gotten wedged under the agitator causing it to lock up.
If you can turn it a little. you most likely have a worn stretched belt or tensioner spring.
The only solution for that is to replace the belt or tensioner spring.
Posted on Dec 06, 2008
GE washer agitation starts normal the progressively slows and then stops agitation. All other modes work fine. Model # unknown. Motor or transmission? Thanx people!!!
Model # located on the back of the control box of top load, just inside of door on front load. Other Op modes ok, problem points to agitator support shaft or the belt drive of the agitator.
Nov 17, 2015 | GE Washing Machines
NEED TO REMOVE AN AGITATOR FROM A WASHING MACHINE
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    GE model WWA8320GAL How to I get the agitator to come off. Thanks for any advice art
    Please read this link below first before you try to remove the agitator.
    http://www.geappliances.com/search/fast/infobase/10002927.htm
    This link below will tell you how to remove the Agitator on the ge washer.
    http://www.wikihow.com/Remove-a-Stuck-GE-Washer-Agitator
    Jul 07, 2011 | Washing Machines
    How to remove agitator from GE washer? Model WHDRR418G1WW.
    how to remove agitator from GE hydrowave washer machine?
    Feb 27, 2010 | GE WBSR3140DW Top Load Washer
    GE Washer WJSR2080V3WW will fill, spin and drain but not agitate.
    The problem is the agitator coupler (about $ 7.00) simply pull straight up on the agitator - Give it a good tug. take the one bolt holding the coupler off - pull straight off. Replace the coupler and bolt (they are sold together). Line the agitator lines up with the coupler lines - when they line up it should go all the way down and snap back into place. and your done.
    Sep 01, 2009 | GE WJSR2080V
    GE Wizard Top-Load Washer - Burning Smell
    sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
    Jul 07, 2009 | Washing Machines
    GE washer not agitating
    when you pulled up agitator was the splined shaft moving back and forth ? If so replace the insert in the agitator. If not the problem is in the transmission .
    Dec 11, 2008 | Washing Machines
    Ge elite 110 23012 100 top load washer
    look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
    Aug 08, 2017 | GE Washing Machines
    GE Profile washer
    suspect gearcase ask for estimate first..could be more than new washer
    Jul 09, 2008 | Washing Machines
    GE washer WWSR3090T6WW
    I DONT KNOW HOW TO REMOVE MY AGITATOR PARTS TO PUT IN THE NYLON COUPLING I GOT THE TOP PART OFF BUT THATS THE ONLY PART COMES OFF
    Oct 22, 2007 | GE WDSR2080D Top Load Washer
    Washing Machines Logo
    124 people viewed this question
    Top Washing Machines Experts
