I have a mitsubishi 52 inch t.v. all the sudden it has just a 8X8 inch picture in the top left corner
  • 505 Answers
It sounds like a PIP malfunction. If its an older Mits it may be prone to fluid leak. This is where the cooling fluid from the CRT leaks onto the circuit boards inside and causes problems. Sometimes it will leak onto the signal board, near the PIP module and cause simmilar problems. Unplug and remove the back. Don't touch the fluid its highly toxic. Use a bright light to look for it. A service center may be able to repair if minor.
Posted on Dec 06, 2008
I have a 52 inch samsung with blinking and jumping picture LN52A650A
The problem must be to its T'Con board. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 800 posts to different brand TVs now. Pull up older posts there..
Sep 22, 2012 | Samsung LN52B550 52 in. LCD TV
My Toshiba TV was on like normal, then suddenly the green color seperated from the red and blue.. On the bottom left corner you can see the green is 4 inches up while the others stay at the bottom. So if...
Ur tv have a problems known as a convergence pictures problems,it is dead.Ur tv have any colors lines like R,B,G mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than ur tv have a dead convergence board to causes the tv to have all of these pictures problems.The tv convergence board must have be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 20, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
I have verticle lines on my Mitsubishi LT-52133. the lines are perfectly up and down and the picture in the middle is good but about 4 inches on the left is dark and miscolored and 4 inches on the left are...
That is not good, it can be as bad the LCD panel is bad which is more likely or the LCD panel inteface board betwwen the screen panel circuit and the main video processor board.
Nov 03, 2009 | Mitsubishi LT-52133 52 in. LCD HDTV
Hitachi 65 Inch HDTV (2006) Model
Are these circles at the center or in the corners. Can you see them on blank screen such as input 1 with out anything hooked up to that input. If so, you are looking at a light engine.
Nov 26, 2008 | Mitsubishi WD52527 52" Projection HDTV
Picture is warped. rca 52 inch model p52929
This is hte beginning of a convergence problem. If you can solder, try resoldering the pins on the convergence ICs. These are large black ICs attached to a heat sink and will be marked STKxxx. If that fails to resolve the problem, replace the ICs.
Keep us posted.
Aug 25, 2008 | RCA P52929 52" Rear Projection Television
Convergance IC 52 Inch Mitsubishi
If its the early mitsubishi they are located on the far left side of the chassis looking in the back they are attached to a large heat sink. If you post the model number of your set I can post the correct ICs that you need as well as where to get replacements that have free instalation instructions with pictures.
May 20, 2008 | Dell GX270 P4 256/40/48X/XPP/NONE...
Picture out of alignment
Look in the menu for a manual alignment. From there you should be manually able to adjust each corner and overall color alignment unless other damage has occurred. Try that first.
Apr 25, 2008 | Sony KP-53HS30 53" Rear Projection...
No picture , only sound
Yes, first do self test here in threads or at
Dec 28, 2007 | Mitsubishi WD-52525 52" Rear Projection...
I would open the back, behind the screen and see if the mirror mounts are damaged. if they are it could be almost impossible to alighn the set properly. good Luck
Aug 07, 2006 | Mitsubishi WT-42311 42" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
