Question about Frigidaire 14.1 cu. ft. / 399 liter Commercial Freezer FFU14K2CW
Freezer "leaking" cold water on floor
Over the last month or so, I've had to wipe water off the floor and it has been cold. now there is more and it's taking two big towels to get the water up. The stuff inside is still frozen and the door is shut. what could possibly be wrong and what can I do to fix it?
    President:
  • Frigidaire Master
  • 2,651 Answers
Sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Dec 06, 2008
Need manual for kenmore model 28462---water on floor
Contact Whirlpool to see if a manual is available. Whirlpool makes Sears Kenmore.
Aug 15, 2015 | Kenmore Freezers
I've had the refregerator for 10 months.. All of a sudden water is appearing on the floor next to the refrigerator. Where could it be leaking from?
Pull it forward and seei if the drain pan is either overflowing or empty. If it,s empty, check the drain isn't blocked, causing meltwater to leak from inside. If it's overflowing, check the door seals properly and the defrost settings are ok.
May 22, 2012 | Samsung RFG297HDRS 29.0 CuFt French Door...
JENN AIRE LEAKING WATER ON FLOOR. NOT SUPPLY LINE PROBLEM. HELP
Open freezer, remove lower crisper & look for solid ice on freezer floor & area at rear of freezer. If present, defrost drain is restricted. Depending on make & model remove ice, remove rear wall and clear defrost drain trough and drain path. Verify by removing kick panel, pour a cup of near boiling water through drain and watch as it drains into pan. Once clear, pour one ounce of bleach into drain tube. Also check as water is draining into pan that the pan is not leaking due to pan cracks. This solution is based on the fact that you are stating no hoses are bad.
Mar 27, 2012 | Freezers
My Siemens KG36U170 fridge (upper) over freezer (lower) continually produces water in the lower section which freezes on the floor inside under the lower container and needs hacking out every couple of...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 22, 2011 | Siemens Freezers
Water leaking onto the floor from freezer drain...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. .
Sep 20, 2009 | Freezers
Hotpoint FZA80 freezer: water leaking
There's a drain hole inside the freezer in the bottom of the back wall ;probably is clogh .Put hot water into it to melt the ice and then blow it with air pressure;keep it clean pouring bleach throught it every 2 or 3 months.
Jul 18, 2009 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Sep 23, 2017 | Frigidaire Freezers
My walk-in freezer is developing stilagtights (ice castles) on the floor and cieling in front of the evaporator coil.MY drain pan is not plugged when I pour water down it.
You should check for air leaks around the door gasket or any other openings in the compartment such as where pipes or wiring is going through the wall. It sounds like a moisture problem from moisture being drawn into the compartment pass door gaskets or access holes.
Mar 07, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
I have a Kenmore upright freezer-model LFFH2067DW2 -the red light has been on for at least 12 hours and the freezer is defrosting-water is leaking on the floor-there is a vent insidethe freezer and the...
I was made aware of your concern and would like to offer a few ideas you may want to consider. Water dripping down is not a leak during defrost condition as this would be the ice melting. Normally, there would be a drain hose specifically to channel the melted ice/water to a drainage system. The amount of water would then be proportional to the amount of ice melting as with the length of time to completely melt, drain away.
Perhaps you could check the filter/drain screen as well as the drain opening for any blockage/clogging. You could also try checking the same on the drain hose as well as for possible kinks. Additionally, there would be a sensor behind a boxy cover that triggers the system back into operation. If there is still melted ice/water inside the freezer, then the sensor would prevent the unit from turning on completely. You may want to check this sensor and verify that it is dry.
An exploded parts diagram would help you identify/locate the above mentioned parts.
Good luck and thank you for using FixYa.
Feb 07, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire 14.1 cu. ft. / 399 liter Commercial Freezer FFU14K2CW Logo
249 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
