Question about Maytag CWG3100A Gas Single Oven
Maytag gas oven takes long time to heat, sometimes not at all
Maytag AGR4410ACH
  • Anonymous May 12, 2009
    I have an Older Maytag gas stove, that takes a loooooooong time to heat up. I went to make pizza the other nite, and it took quite a while to heat up to 400 degrees!!! I had the igniter replaced last year and all was well, 'till now. Is it the thermostat? Is it hard to install myself? I do know how to install a igniter, saw the appliance repair man do it, no big deal. Is the thermostat easy to replace? Please let me know and thank you!!!
  • Anonymous Mar 19, 2014
    Sometimes, my electric oven takes a long time to heat up. The top heater in the oven is working.
    President:
  • Maytag Master
  • 2,651 Answers
Sounds like a bad oven ignitor, part number 12400035 comes with all instructions on how to install
Posted on Dec 06, 2008
Maytag gas oven takes a long time heat and smells of gas.
Important---if you smell gas--I'd be very very careful---could be your control valve or lines to it are malfunctioning or leaking. You might have to call in an expert repair person. How old is the oven? Some preliminary checks you might make are: Do you have a pilot lite or preheaters on the unit? If a pilot lite, make sure it is lit. An unlit pilot lite could sometimes give the smell of gas if malfunctioning. If so, there is is a procedure for lighting the pilot lite--check your user or installation manual. If you have pre-heaters make sure they are lighting up. Normally you have one for the top broiler burner, and one for the bottom oven burner. Check your preheater(s) by selecting either broiler or oven and visually checking to see if they are warming up. After 15 seconds or so, they should be turning bright red. You will see some light coming from them. Check one pre-burner at a time. If they do not come on quickly, shut off the associated valve. Again, be very, very careful with any buildup of gas. It could cause an explosion. At the least it could make you sick.
Sep 12, 2012 | Maytag Ovens
I have a Maytag (Magic Chef) gas oven model CGR3730ADH. The oven will not heat up. The ignitor will glow/heat up but there does not appear to be any gas flow. The top burners work normally. After...
HI,
First of all, thank you for all your information. A rule I live by, even if an ignitor glows does not mean it works. The ignitor works on the flow of electricity through it not how bright it glows. If you can use a amperage meter, hook on one of the two wire to the ignitor directly. You need 3.2 to 3.6 amps to open the safety valve. If lower than 2.6 amps, it will not allow gas to enter the burner. If you have no clue what I am asking you to do, you can purchase and replace the ignitor and life will be better. P# 12400035. Its not difficult to change, the screws holding the ignitor in place sometimes strip out, when you get them off, you can replace them if needed.
Good Luck
Jul 23, 2011 | Maytag Ovens
My oven takes forever to pre-heat and sometimes not at all. Is my heating coil shot?
If your electric oven is taking too longto heat or just not heating up right,then check out this tip that will givemore detail about your problem.
Oven ProblemsElectric Oven is Heating Slowly or Poorly
heatman101
Apr 17, 2011 | Maytag Ovens
My Maytag gas oven is taking a long time to preheat (45min)
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 15, 2011 | Maytag CWG3100A Gas Single Oven
My Maytag Gas Oven will not heat up very much. It's a 50/50 guess if the oven will heat to the correct temp. Sometimes it works fine, the other times it is not very warm at all in the ove, even after...
ello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 06, 2011 | Maytag CWG3100A Gas Single Oven
I have a Maytag Advanced Cooking System (Super Capacity) gas stove. The oven takes an incredible amount of time to preheat & then smell an odor of gas. What could be wrong?
heatman101
Jan 04, 2011 | Maytag Ovens
Maytag advanced cooking system/the super capacity plus
My Maytag , advanced Cooking system , super capacity gas stove has a problem with the oven. It looks like it lights, but most often, doesn't heat up, and I can sometimes smell gas. Anyone know what what cause this?
Jan 20, 2009 | Maytag Ovens
Magic Chef (Maytag) CGS3760ADW - Oven "popping" long time to heat up
It could be air starvation or a temp senser fault.
Regards
Advisor
Nov 17, 2007 | Maytag CWG3100A Gas Single Oven
Crosley gas oven will not heat up
That's my mom!!! Go Sheila!!! Hehe.. -RET-
Aug 08, 2007 | Maytag CWG3100A Gas Single Oven
Maytag CWG3100A Gas Single Oven Logo
697 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
