Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP 6110 scanner glass is cloudy
The glass is cloudy with a streak, but it appears to be on the underside of the glass, and not on top the glass, as I open the cover. It's almost like windows when the seal leaks and they become foggy.
How do I clean the underside?
Thanks for your help!
Lovella
  • Anonymous Dec 09, 2008
    I have the same, glass is getting cloudy underneath, with a stripe as well.
    Wonder, how to get the glass out for cleaning ?
    By every scan there is a sqeaky sound, like something is touchting it.
  • lovellah Dec 13, 2008
    Thanks, I'll give that a try!
    Guru:
  • 1,049 Answers
Here is how, but it seems a lot of work.
- Remove all the torx-screws
- Remove the little glass on the left side
- Remove the Control Panel Cover (lifted it a little with a screwdriver and released two latches)
- Remove the Control Panel itself (another two latches&move to the left)
- The whole top of the 6110 is attached to the bottom with 4 latches. I remove that, turn it around and clean the glass.
Note: The cables between 6110-bottom and control panel/feeding unit are long enough to set those things aside.
Posted on Dec 12, 2008
How to clean the underside of the glass in a HP scanjet 2400
Hi ,
You probably already found this :
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/performMaintDisplay/?sp4ts.oid=297429&spf_p.tpst=psiContentDisplay&spf_p.prp_psiContentDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01275864-2%257CdocLocale%253Den_US&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
According to it , you should normaly contact a HP technician to have the job done . Nevertheless , I succeeded to clean the underside of the glass inside a HP Scanjet 5470C wich seems similar to your model 2400 . If you take of the lid of the unit , you should find two screws in the opening of the hinges . Unscrew them and lift up the the whole top of the unit . You might encounter somme kind of resistance during the operation but I finally succeeded to get the it free that way .
Best regards .
Sep 04, 2014 | HP ScanJet 2400 Flatbed Scanner
Scanner window is cloudy on bottom. needs to be wiped clean
if you are a technical kind of guy you may want to download the service manual from MAISE MANUALS to see the correct proceedure to remove the platen glass without damaging your scanner!
attempting to do this without good instruction will most definatley be a bad day for your printer this job would likely take me about 3/4hr to complete as to remove the glass several covers need removing.
Jan 14, 2014 | HP Photosmart C6180 All-In-One InkJet...
How do I remove Scanner Glass to clean underside.
jast go and download service manual for 6110
http://h10032.www1.hp.com/ctg/Manual/bpd09762.pdf
. Read it. Then try to open your printer's glass.
Thank you
Jun 01, 2013 | HP Officejet J6410 All-in-one InkJet...
How to clean the underside of the scanner glass on an HP4400C flatbed scanner.
This is acutally easier than it looks. I just had the same problem with a cloudy film starting to form underneath the glass on my older HP 4400C scanner.
First completely remove the hinged top lid by lifting straight up on both long ends of the lid - notice the 2 hinges on the back end of the lid will come straight up and out of the body of the scanner, still attached to the lid.
Next look down inside the 2 hinge holes (on the main body of the scanner where the lid hinges just came out of) and you will see a screw in each hole. Remove both screws using a phillips screwdriver. This will allow the rear end of the scanner to come apart enough so you can now lift it up a few inches to separate it and get your hand inside there to clean the underside of the glass with a soft cloth - BUT JUST REMEMBER THE FRONT END OF THE SCANNER WILL STILL BE CONNECTED, so don't pull it too far apart because it could snap and break something that is still holding the front end together. (I could not figure out how to separate the front end piece, and then I realized I didn't have to).
So on the rear end of the scanner, now carefully pull the light upper colored plastic apart from the lower dark plastic just enough so you can get your hand inside the compartment and use a soft cloth to clean the underside of the glass. I just used a small piece of an old cotton t-shirt with a couple little dabs of water on it and then just kept rubbing the dirty areas on the underside of the glass over and over until all the dust film/streaks disappeared and the glass was once again clean and all clear.
Then gently lower the glass back down and line up the plastic pieces together on the rear end and put the 2 screws back in the hinge holes, and then reinsert the hinges in their slots and lower the lid back on top of the scanner glass and it is ready to go again !!
Hope this works for you like it did for me.
Nov 19, 2010 | HP Scanjet 4400c Flatbed Scanner
My HP3030 scanner glass is dusty on the underside
Yes you can. Just be careful not to force any movement of the scanner lamp. Be gentle. Otherwise you have nothing to fear.
Apr 08, 2009 | HP LaserJet 3030 All-In-One Printer
Streaks when scanning and the glass needs cleaned how do I get in to clean the glass on the underside
Here's a link to the instructions for opening the top of the scanner:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00553775&dlc=en&product=90809
BG
Oct 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Scanner failure hp 6110 - Noise and stuck head
the error message refers to the hardware issue of the printer. Below is the document that i need you to follow to somehow resolve your issue.
CLICK HERE==>> DOCUMENT
Please let me know if the document that i gave to you resolves your issue.
thank you so much.
adonscott
Jul 19, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp office jet 6110 all in one
THE Office Jet 6110xi has the problem is the scanner carriage having a problem when it looses power. The carriage does not "see" the signal it needs to indicate to the scanner carriage has reached the end of the scan deck -- I open the scanner top (remove screws, lift ONLY several inches leaving the front "clips" or "clamps" connected so the rear part of the top deck lifts up).
I have wiped the glass and the scanner carriage.
THE BEST THING THAT SEEMS TO WORK IS TO MAKE SURE THE THIN PLASTIC INSERT BETWEEN THE GLASS AND THE PLASTIC DECK --- WHICH IS NOT SEEM FROM THE TOP SCANNING DECK BUT ONLY FROM THE UNDERSIDE WHILE HOLDING UP THE DECK --- IS PROPERLY SEATED SO THE SCANNER CARRIAGE "SEES" IT.
ALSO HAVING WORKED IS SOME COMPRESSED AIR BLOWING IN THE SCANNER CARRIAGE AREA. I PRESUME SO DUST GETS IN THERE AND THE AIR REMOVES IT.
This happens almost every time the scanner/printer looses power, so I usually try to avoid unplugging it or shutting it off!!!
Finally, do not give up. This can be fixed. Sometimes it took 2 minutes, sometimes it took an hour of cleaning, wiping, blowing air into it.....
M
Mar 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
733 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
