Question about RCA HD52W59 HDTV Projection Television
Me again TV is driving me crazy....
I swear the TV is really makeing me mad. First it curved and the colors were missed up. So we replaced the fuse and it worked for a while. Then we lost the sound made sure things were hooked where they needed to be, seem to be doing okay. Then the power started kicking off and on before you knew it, it blew the fuse. Took the air compressor and aired it all out replaced the fuse and it seemed to work, day later it blew again. Only have one fuse left. Any ideas before I shot this piece of ****. This RCA TV is really a piece of **** if you ask me. FYI --- You have really been a lot of help.
    Genius:
  • 1,030 Answers
Ok let see what we can do. These rca can be trouble. Im a technician and i see these alot. I guess that a good recomendation for these set LOL. First question. I take it you had the FL231 fuse problem... YOu replaced the fuse did you do the most important step. RESOLDER the flyback connections. i beleve that is step 7 in the instruction. this is the main reson this fuse blows. i have run into only one other case ...out of the hundreds of fuses i have replaced where the small signal cuircit board cause it to blow. but like i said very rare. i used to just put that fuse in and not resolder... it would come back to me within a day. LEt me know what happens
Posted on Dec 06, 2008
1998 ford escort zx2 car runs great till it reachs normal operating temp range then it misses like crazy. put in a new fuel pump that didnt help tried new coil pack that didnt help either its not over...
ignition module , that the coil packs sit on ,was the problem on my car. had the same symptoms .ran fine till it warmed up then it started missing like crazy
Nov 03, 2013 | 1998 Ford Escort
Focus 1.8 tdci 2009 won't start dash lights go crazy noise from fuse box
check your battery cables for corrosion clean them and start the engine
Mar 25, 2013 | Cars & Trucks
Have a 32 in polaroid hdtv and the color is all messed up-tried to adjust it in the USER controls (contrast, sharpness, brigtness, hue and saturation) but I can't seem to get the color right, it either...
Actually it sounds like your component cables need to be changed. If you are connecting with component cables please try another set (if you buy a new set like from Radio Shack make sure you can get a refund if that is not the problem and you need to return them).
Mar 08, 2011 | Polaroid 4011-TLXB LCD TV
Hello. we have a lexmark 3100 color printer/copier and it is driving us crazy!! we change cartridges every time you turn around and lately when we change them we still don't get any improvment in the...
If it's driving you crazy and it's a Lexmark, yes, get another printer. This problem is not worth the headache and money to fix. It makes me crazy, too, when someone brings in a cheap printer for me to fix and have to turn around and tell them it's garbage because the problem involves proprietary test equipment from the manufacturer.
Dec 21, 2010 | Lexmark Office Equipment & Supplies
Picture is curved like an hour glass
that a pincushion problem likely caused by a failed capacitor
Mar 26, 2009 | RCA Televison & Video
Print is dull.
Listen I have seen really, bad print ctgs from HP, before you drive yourself crazy replace the ctgs again, see if your print quialty improves. just cause it's new doesn't mean it's not defective.
Mar 07, 2009 | HP DeskJet 5150 InkJet Printer
Change in color, computer problem inside TV
For "thechances", The LVDS cable has gone bad. This cable connect between the mainboard and the panel. The replace the cable will fix the problem.
Feb 17, 2009 | Vizio L32 32 in. LCD HDTV
HL-P5063W vibrating and won't turn on
i have had this happen to me several times in the field, and if it is what i think it is, you are not going to be happy =(
inside of a DLP type TV, there is a device called a 'color wheel'... it is essentially a disc made up of different colored glass that spins really fast. this disc has 3 or 6 (depending on make/model) pieces of colored glass like pieces of a pie affixed (read: glued) to a hub.
what happens sometimes is that one of the pieces of colored glass flys out of the hub, and causes a massive unbalance in the spinning wheel, which causes the hum/vibration, and since the colored glass is missing, the colors will be all messed up.
if this is what happened, then your television will require a new DLP engine.
Dec 08, 2008 | Televison & Video
Auto door locks 92 sport inline six
Sounds like you have a couple of problems:
1. Door locks will most likely be a bad fuse. Check all of your fuses under your dash with a 12V test light. test both sides of fuse to be sure.
2. Rear hatch will unlock using a key with or without power. Spray some graphite spray into the key hole to lube it up and try again. WD-40 works but it is not as good. When it's cold, vehicle locks will be harder to open and require extra lubrication.
Nov 20, 2008 | 1998 Jeep Cherokee
RCA R52WH77 convergence missing from menu
THis is very common on these sets. there is a special fuse thats cause this.. kinda hard to get rca part number 259213.. .4 amp. the reason this blows is there is bad solder connections on the flyback. so when you replace this fuse you have to resolder these connections. so if you know how to solder and can find this special fuse. it is a fast and easy repair
Apr 08, 2008 | RCA P52937 52" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
66 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
