Question about Dell Dimension C521 PC Desktop
Output device my audio system dont work please help me with this can you?
    Sergeant:
    Champion:
  • 275 Answers
What do u mean audio system do u mean to say no sound comes at all ?
if yes first try with a working speaker or a head phone if still no progress go to device manager
right click on my computer > properties > hardware > device manager > and delete everything which is under audio and game controler > restart the system
and than try see you have sound
if your sound card is good ur issue is resolved
Posted on Dec 06, 2008
My pc says no audio output device installed,but in device manager it says its working properly and the drivers are up to date
Well it is possible that the audio driver installed is not the one compatible with you computer board. Try downloading the specific driver needed for your computer's official website. This should solve your problem.
Sep 06, 2011 | Computers & Internet
"no audio output device is
I understand that audio output device is very important to a laptop. But don't worry there's a website where you can download the device for free.
Please just click_here so that you will be directed to the exact site.
Thanks.
Aug 22, 2011 | Compaq Presario 700 470024-192 Notebook
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
No Audio output devices is installed
you need to install a vista driver for your sound card. First check if your sound card is vista compatible
Aug 27, 2009 | Microsoft Windows Vista Ultimate Edition
Please help? i have audio device; i can play music and movie but there is audio output. how can i fix it? any help please! thank! from curt.shane@yahoo.com
Make sure your audio properties are set to the correct output. If you have a second sound card, this is the most common problem. On older systems, the PCI sound card takes over as your primary source of sound output and input, therefore your onboard sound is useless. If neither of these solutions help, it might be a problem with yoru speakers and in that case you will want to check to make sure they are working properly. If this does not work, go into your BIOS(assuming you are using onboard audio) and make sure your audio device is enabled, however this is unlikly beucase it would probably cause problems with windows media player when trying to play any audio. Lastly, there is always the chance that the audio is simply malfunctioning and windows media player, nor the rest of your computer realizes it.
Jul 03, 2009 | Microsoft Windows Vista Ultimate Edition
My Acer Aspire 5315 says I have no audio output device
do you think you got a virus or spyware on your system, i would first try system restore on the start acc,system tools system restore
set back to last week ,
if that dont work needs to reinstall windows
Mar 14, 2009 | Aspire Acer 53152826 Notebook
Audio output device
It is most likely you have a device that needed a special installation of a driver in order for it to work. The most logical solution in this case would be to reinstall your audio driver from the disc the driver is contained on.
Also, check Windows Update to see if a sound driver is offered as an optional update.
Aug 23, 2008 | Microsoft Windows Vista Ultimate Edition
NO AUDIO OUTPUT DEVICE IS INSTALLED
windows key + R = open : devmgmt.msc
Sounds, video and game controlers > (right click) Realtek high definition audio > update driver sofware > browse my computer for driver software > let me pick from a list...> double click on Realtek high definition audio > YES to update driver warning > AND SWEET SOUND IS AUDIBLE :D
Dec 14, 2007 | Microsoft Windows Vista Ultimate Edition
Dell Dimension C521 PC Desktop Logo
Alun Cox
