Question about Belkin (F5D7230-4) Router (587009)
Reset belkin router F5D7230-4 to factory defaults
Currently unable to connect to internet
  • christine46 Dec 07, 2008
    i nolonger have the box i bought this belkin .. when i try to get on line with my laptop it shows that iam connected but when i go to log in to the internet it states can not open,, i need help
  • jdm2 Jan 05, 2009
    Computer recognizes the router but does not connect to internet. I am directly connected to a working cable modem via ethernet cable. I tried re-booting both modems with no luck.
My belkin f9k1002v1 router won't work.
A lot of things can keep it from working. Make sure there's lights and you have power, substitute ethernet cables, do a factory reset. Here's how I did the factory reset on my F9K1003V1.
Nov 02, 2012 | Computers & Internet
Tip
Wireless Network Reset - Belkin
If you are unable to connect your laptop wireless to your <b>Belkin</b> wireless access point/router, the <b>easiest</b> and<b> fastest</b> way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.<br /><br /><br /><br /><b>Reset your router:</b><b><br /></b><br /> <ul> <li><b>Unplug</b> your <i>DSL/Cable</i> <b>modem</b> from power (not your access point/router) Leave this unplugged for now</li></ul><br /><br />Next <ul> <li>On the rear of your<b> Belkin router </b>you will find a small RESET button</li> <li>With the power still on the router,<b> Press</b> and<b> hold</b> (with a pin/pen tip) the <b>RESET</b> button for 10 seconds.</li> <li><b>Release</b> the RESET button a wait 15 seconds for the router to reboot</li></ul><br /><br />almost done.... <ul> <li><b>Unplug</b> your <b>Belkin</b> router from power</li> <li><b>Plug</b> your DSL/Cable <b>modem</b> back in to <b>power</b></li> <li><b>Wait </b>1 minute for the modem to boot up</li> <li>Be sure the ethernet (cat5) cable from your <i>modem</i> is securely plugged into the <b>WAN port</b> on the back of your Linksys <i>router.</i> This is usually labeled <i>WAN</i> or<i> Internet</i> above the jack</li> <li><b>Plug</b> your Belkin <b>router</b> back into power.</li></ul><br /><br />You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.<br /><br /><b><br /></b><i><b><br /></b></i><i><br /></i>Magoo
on Mar 13, 2011 | Computers & Internet
I changed my router wep key password code and now I cannot connect to the internet; how do I fix this problem? It does not recognize the connection now and I cannot go back in to change it back to the...
This is how you reset your router.....
Reset the router to factory default With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings.
How to setup new router:
  • 1 Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password.
  • 2 Unplug your router and your cable or DSL modem.
  • 3 Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports.
  • 4 Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer.
  • 5 Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties.
  • 6 Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically."
  • 7 Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1.
  • Read more: How to Set Up a Belkin Router ' eHow.com http://www.ehow.com/how_2292408_set-up-belkin-router.html#ixzz19MK9oA2A
    Dec 27, 2010 | Belkin Computers & Internet
    I reset my router back to factory default and now I am unable to get an internet connection :(
    Check your internet connection settings. If you are using a connection that requires a username and password to connect to the Internet (such as phone-line based DSL or Dialup), It will need to be set up again. If you forgot this account information, or don't have it handy- you will need to contact your ISP for further assistance.
    Dec 26, 2010 | Belkin (F5D5231-4) Router
    My belkin wireless router is locked. How do I unlock it?
    If you have forgotten the login password you can RESET the Belkin back to the factory defaults and configure it again.
    THEN
    Power up the Belkin and press the RESET button for 7 secs.
    The default login password is blank.
    Please let me know if you have any further questions or concerns.
    Thanks.
    Apr 23, 2010 | Belkin (F5D7230-4) Router (587009)
    Conntection problems
    1. physical connection
    ISP modem to> router yellow port> router grey port to ur computer
    2. modem light on the router should be solid and the internet light also.
    3. if not u need to configure ur router
    4. open the ie or firefox in ur computer which is hardwired to the router
    5. type 192.168.2.1 i the address bar it will lead to belkin router page
    6. if the modem light flashes on the router then in the belkin page on the left side click on the restore factory default
    7. it will ask for the login password leave it blank click on submit
    8. then click on the restore default
    9. in the rite upper right corner it has to say connected
    10. then disable the wifi protected setup by clicking on it on the left side
    11. then u will be good to go with the wired and the wireless connection
    Feb 08, 2010 | Belkin Computers & Internet
    Laptop wont connect to wireless belkin router
    If you connect the laptop wired, does it work correctly?
    If your Wireless router has password protection, try resetting it to factory defaults, and connect it that way.  If you can connect with the factory defaults (with no security), it's likely an issue with the security on your router.
    I'd suggest starting again. Reset to factory defaults, re-secure the network and try a different SSID name this time, and try again.
    Mar 18, 2009 | Gateway 802.11g Wireless DSL/Cable Router...
    Cannot connect my Mac Pro to the internet via my Belkin wireless
    This will make the router unsecured again, so be sure to go back into setup and reset your Wireless security. I suggest using WEP authentication, and using a 10 digit ph # for your key (that way its easy to remember).
    Dec 31, 2008 | Gateway 802.11g Wireless DSL/Cable Router...
    Can't connect to Belkin N1 Wireless Router
    when you reset the router to factory defaults everything goes back. so try to connect with cat5 cable and in IE link bar type 192.168.2.1 and you will get the set screen of the router admin and password sholud get you in the you can look at the settings wep, etc. then change you pc to match
    Mar 28, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
    No wifi connection
    Verify which MAC Address U have Cloned. MAC Address of Your PC WiFi and Cloned One must not be same otherwise it will not work...
    Feb 02, 2008 | Belkin (F5D7231-4) Wireless Router
    Belkin (F5D7230-4) Router (587009) Logo
    3,733 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
