Question about Sharp R-930AK Convection/Microwave Oven
Sharp microwave R-9320AK
Has anybody else had this problem. A new microwave, only used three or four times to heat up food --- maximum 2 mins. Four - five hours after use exterior top of oven burning hot to touch - so much so scorched a packet of Asprin...what is the likely cause...thanks very much for any advice
  • 38 Answers
Hi you first need to check if ur fan is working ifnot replace if is replace magnetron and faulty thermal cutoff switch
Posted on Mar 18, 2007
It is a Daewoo MicrowaveThe microwave does not heat up the food! It is only about 18 months.Tried to to re_set but nothing happens as the food remains frozen or cold!Anybody has any suggestions?
There are three parts that could be bad. One is a high voltage diode, another is a capacitor and the third is the magnetron itself. If you are not familiar with these terms, it is time for a new microwave oven.
Oct 21, 2016 | Daewoo Microwave Ovens
Unable to eliminate odour from previous cooking despite the fact that I wipe the microwave with a soapy cloth & then with a clean cloth each time to Microwave is used
  1. Fill a plastic bowl with 1 qt. of warm water. Add 2 tbsp. of liquid dish soap and 1/4 cup of chlorine bleach to the water. Thoroughly mix the solution.
  2. Dampen a clean cotton rag in the solution. Wipe all inside surfaces of the microwave with the soapy rag to remove food debris and stains. Scrub stubborn residue with a nylon scrub brush.
  3. Moisten another cotton rag with warm water. Wipe the microwave surfaces with the rag to wash away soap and loose food debris. Thoroughly rinse the inside of the microwave.
  4. Dry the microwave's interior surfaces with paper towels. If odors remain in the microwave, fill a microwave-safe bowl with 1 cup of cool water. Add to the water 2 tbsp. of baking soda, half of a chopped lemon (including pulp and rind) and four whole cloves.
  5. Place a microwave-safe plate on the microwave turntable. Set the bowl on the plate.
  6. Heat the microwave on high for three minutes. Operate the microwave according to the manufacturer's directions. Keep the bowl in the microwave for 15 minutes.7
  7. Remove the bowl from the microwave. Wipe the microwave's interior surfaces with clean paper towels to remove steam moisture.
  8. Leave the microwave door open overnight to completely air out any remaining odors.
  • Sep 05, 2012 | LG LTM9000 Microwave Oven
    Machine not turning on
    1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
    2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
    3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
    4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
    Hope i could help you.
    Have a nice day : )
    Sep 04, 2011 | Microwave Ovens
    Microwave has no power when plunged in
    1) Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
    2) Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
    3) Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
    4) Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
    Apr 04, 2011 | Maytag Microwave Ovens
    Microwave KB-6024MS does not heat.
    This indicates three parts that can be the culprit, the magnetron "common problem" or the high voltage capacitor or diode, all three work together to heat food. Depending on the nature of the repair will determine the price for parts and labor and may approach the cost of a new one.
    Feb 28, 2011 | Sharp KB-6015KS Stainless Steel 1000 Watts...
    Not heating food but will heat plate. wont pop popcorn. takes three times as long to heat food even if on a paper plate
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    Mar 04, 2010 | Sharp R-55TS Microwave Oven
    Sharp microwave losing cooking power
    If the supply voltage is low it will take long time to heat foods. The second reason is the Magnetron. Since it is in the warranty period you can call at the sharp authorised service center. They will do it free of coast.
    May 04, 2009 | Microwave Ovens
    GOLDSTAR MV150W
    HAS NO POWER AT ALL. WHAT COULD BE PROBLEM
    Sep 22, 2008 | Microwave Ovens
    Sharp R-930AK Convection/Microwave Oven Logo
    76 people viewed this question
    Top Sharp Microwave Ovens Experts
    William Miller
    William Miller
    Steve Allison
    Steve Allison
    Jaime Hernandez
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
