Question about JVC KD-DV4200 Car DVD Player
Replacing a stand alone dvd receiver with this unit-wiring help needed
Just purchased this unit to replace my audiobahn stand alone dvd unit under the passenger seat of my minivan. There is the power and ground wires already in place along with the yellow video and audio RCA wires from the old unit. Seems like a simple swap of units but the instructions refer to a switching wire being needed and a parking break wire. I wish to only use this unit for DVD playback...dont care of radeo or other playback. Do I have an install nightmare here or shall I take to Best Buy and pay for an install...please advise. if easy and only need to find a switching wire...where do I find that...in the dash of where my existing stock radio is??just splice and pull under the carpet to the other wires already in place?? Any help or advise is appreciated.
SOURCE: jvc KDAVX44 install issue
No, you do not need to connect the parking break wire for the unit to be powered. My radio worked when the parking break wire wasn't attached, but you cannot watch video's or use USB without attaching it to something... you can bypass the parking break to a switch if you like.
Posted on Jul 08, 2008
SOURCE: DVD playback
connect it to ground and you have all the time DVD :)
Posted on Apr 12, 2009
Installer1
  • 97 Answers
SOURCE: jvc kd-sx750 head unit has power but puts out no sound
bro to me it sounds like your radioi is bad you got everything hooked up right to get sound from it maybe the ant. hooked up but you should still get sound thats why I say the amp in the unit is bad!
here a little help: red: ignition when the key is turned on
yellow or orange: all time 12v
black: ground
blue: amp turn on, or auto ant.
Posted on Aug 20, 2009
Testimonial: "thx alot i was think that the radio was bad i got it off creiglist for 25 bucks i guess the deal was to good to be true "
Raditronic
  • 196 Answers
SOURCE: jvc unit
check down the radio. down the radio is the diagram chart.
Posted on Apr 28, 2010
  • 16 Answers
SOURCE: 1996 Chevrolet Tahoe
Re check your wires and make sure none a crossed, if you are using black tape make sure the wires are not poking threw the black tape and touching
Posted on Jun 03, 2013
Hi my compreesors power switch is stuck wont turn on of
Is it a stand alone unit or a mains powered unit?
If it is stand alone you might have to disconnect any battery fitted and remove the switch. Remove the wires from the back of the switch.
If it is mains powered either unplug it at the wall or remove the fuse at the main fuse panel. Replace the switch and reconnect the electric supply.
Sep 18, 2018 | Cars & Trucks
Powerseat on 2002 ford windstar blowes 40amp fuse with motor unpluged
You have a dead short to ground on that circuit ! Passenger seat ? Do you know what a wiring diagram is ? How to test for a short to ground ? Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. year , make , model an engine size . Under system click on body & accessories , then under subsystem click on power seat . Click the search button then the blue link . Somewhere between the fuse box an the power seat connector that wire is touching ground ( metal on the vehicle body ) . Videos on youtube showing how to find short .
Feb 23, 2018 | Ford Cars & Trucks
2000 Buick Lasbra third brake light not working working replace the bull b.s. and still.not working
Did you test the socket for power and ground? If no power, check the splice under the driver's seat--3 white wires. If no ground, check the connection in the truck on the passenger side.
Oct 21, 2017 | Buick Cars & Trucks
Power Seat
The passenger seat has a separate drive system. Check and make sure all the electrical connections are proper. Sometimes the switch goes bad. You can "Carefully" take the switch out of the side of the seat and check the continuity of the switch. It also could be shorted out because some lame brain crammed something under the seat and broke the ground wire. You did not mention what kind of a car you are driving. So, maybe the answer is all wrong. A loose ground wire can cause the seat not to work.
Apr 25, 2014 | Cars & Trucks
Driver side window wont roll up
Could be the motor. I would try seeing if the ground came loose. Same thing happened to my passeneger window. I reconnected the ground and it works like it never quit. Try the wiring under the passenger and driver seat. The ground for the passenger window in my car was under the passenger seat.
Feb 08, 2010 | 1995 Buick Riviera
What is the color code for the stereo wires in an 08 land rover l
Battery BROWN/LIGHT GREEN(+)IGNITION SWITCH HARNESS
Ignition 1 WHITE (-) IGNITION SWITCH HARNESS
Accessory 1 WHITE/PINK (-) IGNITION SWITCH HARNESS
Starter 1 WHITE/RED (-) IGNITION SWITCH HARNESS
Tachometer WHITE (-) AT IGNITION COIL
Speed Sense YELLOW/GREEN (AC) AT MODULE UNDER PASSENGER SEAT
Parking Lights ORANGE/RED (-) AT MODULE UNDER PASSENGER SEAT
Brake Lights GREEN/BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Power Unlock BLACK (-) AT MOTOR IN DRIVERS DOOR
PowerLock BLUE (-) AT MOTOR IN DRIVERS DOOR
All Door Trigger VIOLET/GRAY (-) IN HARNESS TO RIGHT OF STEERING COLUMN
Trunk Trigger VIOLET/YELLOW (-) AT MODULE UNDER PASSENGER SEAT
Hood Trigger VIOLET/WHITE (-) AT MODULE UNDER PASSENGER SEAT
Headlights-Lo BLUE (-) AT MODULE UNDER PASSENGER SEAT
Wipers-Lo PINK/LIGHT GREEN(-) AT MODULE UNDER PASSENGER SEAT
Trnk Release WHITE (-) AT TRUNK RELEASE SWITCH
Battery RED/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground TAN (-) RADIO HARNESS
Illumination GRAY/BLUE (+) RADIO HARNESS
LF Speaker (+) BLUE/WHITE
LF Speaker (-) TAN/WHITE
RF Speaker (+) RED
RF Speaker (-) TAN/RED
LR Speaker (+) RED/GREEN
LR Speaker (-) TAN/GREEN
RR Speaker (+) BLUE
RR Speaker (-) TAN/BLUE
Radio Security YES
(thats for 07 but shoe to what u need)
Aug 24, 2009 | Alpine Car Audio & Video
Hello, I purchased a set of Pyle Headrest Dvd's for my 2004 Nissan Armada and the instruction are not that easy to understand on how to install it. Do you know where I can get the instruction or can you...
Yeah, Ive come across too many so called instructions that are pure ****. Normally, the stand alone units have one RCA for video input and power/ground. Simply run single RCA to each with switched power and solid ground. Some have muli video inputs too for video/game ect... Contact Pyle for wire color issues.
May 08, 2009 | Car Audio & Video
My 95 Jeep GC's little display computer goes blank.
I don't remember that being a very common problem for the Vehicle Information Center. Sounds like you may need to replace the unit to solve it. But try this first. Most of the dash circuit grounds are actually grounded under the drivers seat under the carpet. I was dealing with some dash electrical issues for my friend. She didn't realize she had over a inch of standing water under the carpet. The harness was laying in water. The carpet is pretty water tight so the water didn't evaporate.(I found an hole in the firewall for an accessory that was not longer there) Try to feel under the carpet and see if it is wet. If so pull the seat, get the carpeting pulled up and get dried out. Then make sure clean those grounds.
Mar 29, 2009 | 1995 Jeep Grand Cherokee
Kenwood dnx 7100 e brake over ride - DVD
It is a light green wire. It should have a sticker on it that reads "to emergencty Brake"
I just grounded mine to the same black wire ground of the main radio. It works fine.
Jul 30, 2008 | Kenwood DNX7100 Car Video Player
Power cable for A1451
yes if you will open up the unit and look on the circuit board that it connects to it is labeled plain as day what each plug is (b+, gnd..) find that out and thats how ya do it
Apr 15, 2007 | AudioBahn A1451 10-Disc CD/DVD Changer
JVC KD-DV4200 Car DVD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
