Question about Boss Micro BR Digital Recorder
MY Boss br 1180 ,disk error
When we turn on the boss br 1180,it turn on the then it goes to checking then to drive errror .What do we need or what can we do to get it running???
  • Anonymous Dec 10, 2008
    I was burning a song onto a CD-RW. When the BR-1180 prompted me for finalization of the disc, I selected NO so I could burn another song onto the CD-RW then the BR-1180 froze up. While it was froze, it was making a loud buzzing noise. I manually unplugged it from the output. I waited a minute or two then plugged it back up, turned it on, and now it is doing the same thing your's is doing. Also, I tried finalizing the disc after all this happened and it gave me a MEDIUM ERROR message. Neither of these error messages are stated in the Owner's Manual.
    New Friend:
  • 27 Answers
Before you go out and buy a new hd try intializing your system.
unfortunaly you will lose all saved info, but you will either way. this test may save you some money.
with your 1180 in the off position press and hold the track 5 button below the fader and the redo/undo button that is just to the left of the rotarty knob and below the power button. while holding these two buttons press the power button and continue to hold the track 5 button and the undo redo buttons untill the test menu is showing. its takes about 15- 30 sec. in the test menu rotate the value knob till you see 23 initialize HDD and press ok. this process may take up to 30 mins. if this doesnt fixya then contact roland for a replacement.
Posted on Feb 26, 2009
  • relyonmick Aug 28, 2010
    Just want to thank you for this information. I tried it and even though I,ve lost all my recordings, I,m just happy to be able to record again! This worked on my BR1200CD. Where did you get this info in the first place?
For help on backing up and replacing the hard drive, check here: http://juho-eric.blogspot.com/2011/06/boss-br-1180-hard-drive-backup.html
Posted on Sep 22, 2011
Unfortunately this does fix the problem but clears all the data so you lose everything. BACK UP consistently and constantly.
Posted on Jan 27, 2010
  • 716 Answers
The Humming Is Normal When The Unit Is Not Properly Placed On Something That Is Level Make Sure You Find A Flat Part On Your Dresser Or Wherever It May Be. I May Add DO NOT EVER UNPLUG THE BR-1180 WHILE IT IS RUNNING Unless You Like Losing All Your Data. As For The Hard Drive Problem Call Roland They Are Extremely Helpful. It Is Unlikely That Your Whole Hard Drive Is Fried
Posted on Jan 05, 2009
I m afraid i have a bad news, you need to replace your hard a 20 GB memory
Posted on Dec 24, 2008
  • morineric77 Dec 24, 2008
    replace your hard drive
  • diiiiixxx Jun 16, 2011
    Check this websitehttp://juho-eric.blogspot.com/2011/06/bo...
    for info on how to back-up and change the hard drive on the BR-1180.
My Boss BR-1180 was working fine but said NO CD DRIVE so I replaced the cd drive and as soon as I did I turned it on it reads BOSS BR11-80 and the HD ACCESS light stays lit but nothing else happens. Did I...
hdd should not be damaged, if your hd and cd are on same ide cable it might be taking the cd as master and not the hd, ensure the jumper on the back of the new cd drive is set in the same position as the old one was, as test remove cd and boot system, hd should act again as usual. this will show that there is a ide conflict.
my assumption is that your cd jumper should be set to slave or cable select position.
you may have to try each until you find the position that works.
I hope this was useful.
regards Martin.
Mar 24, 2011 | Boss BR-600 Digital Recording Studio
My Boss br-8 keeps saying medium error. It's not reading any disc. It ask me to initialize disc that already have music on them.
If the disk had music that was not CREATED on the BR-8 you will get the error. The format is incompatible with computer formats.
If the files were created on the same BR-8, then you probably have a disk drive failure.
Try initializing a blank disk. If it will not, then you have a drive failure.
Also is it possible you are trying to read a 250Mb disk on a 100Mb drive? That won't work either.
Jul 25, 2010 | Boss Micro BR Digital Recorder
BR-1180 freezing & high-pitch ring
Check your power supply to the unit. Low voltage COULD cause this.
Also make sure a setting is not "looping" the audio back into itself.
May 23, 2010 | Boss Micro BR Digital Recorder
Burnt out my Boss BR 1180 How do I repair?
this is a job for an advance electronic repair tech...try the manufacturer..next a tv repair shop..then an Audio Install shop...if that doesn't work out..i'll personally try to fix it..for lest than anyone else..its probably the tranformer output circuit overrun..that part of the board or component wil have to be replaced...good luck
Jun 16, 2009 | Boss Micro BR Digital Recorder
What do I need to burn a cd from my pc with the br 1180
This Is real simple grab a cable that goes from rca jacks to a headphone jack then plug the rca jacks into the br-1180's audio out jack and then plug the other end into your computers mic port.
Download Audacity From www.Audacity.com and then use it to capture you audio and then you can burn that when complete.
Its real simple I do it all the time even though I have the br-1180cd the cd burner burns real quiet so I don't use it. The cable can be bought at radio shack, best buy, wal-mart and I have even seen them at 99 cent only stores.
If you have more question let me know This Is my main unit so I know a lot about it.
Sincerely,
Michael Scott
Apr 29, 2009 | Boss Micro BR Digital Recorder
No CD writer for Boss BR-1180
Hey mike yeah you can hook a regular cdr drive to the ribbon but the problem is if its not a slim it most likely wont fit inside the unit. Also the built in c.d r is way over rated mine has it and I still bounce it all onto my computer and then burn it from there. The one on the br-1180cd burns very quiet.
Apr 23, 2009 | Boss Micro BR Digital Recorder
Boss 1180 Hard Drive Error
Im Sure You Solved This Problem But For Other User Yes There Is A Way To Save Your Data If Your Hard Drive Is Still Operable. You Can Put Your Boss Hard Drive Into Your Computer And Copy Its Contents To Your Computers Hard Drive. Some Say That If The Hard Drive Is Not Operating You Can Put It In A Ziplock And Then Stick It In The Freezer For An Hour Then Attempt To Retrieve Your Info. Remember Always Back Up Your Data On Hard Drive Recorders As They Are Not Fail Safe.
Apr 13, 2009 | Boss Micro BR Digital Recorder
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
Boss Micro BR Digital Recorder Logo
2,607 people viewed this question
Top Boss Music Experts
Michial Gueffroy
Vito Vacirca Jr.
shaun taylor
Are you a Boss Music Expert? Answer questions, earn points and help others
