I have a Mazda mx6 and the aircon won''t work.
what won't work? the interior fan or is all else well except the cooling part? if the compressor does not come on, then perhaps you need to refill gas. in the very front of the car under the hood, you remove the plastic covers where the hood opener is, and you will see some pipes & a canister. on top of this canister there is a clear small round site glass, you can check there for gas if you have dye, or you can unscrew the cap over the refill nipples and depress with you finger nail, air (gas) should blow out under good pressure, not a little only. there is also a fuse you can check situated in the same place, this is for the compressor
