Question about Frigidaire 24 in. FDB1051RE Built-in Dishwasher
Wont start When I push the start button, the washing light starts to flash, but the dishwashing cycle won't start.
  • 44 Answers
The lights flash when the door is not shut all the way, or the sensor that detects that the door is shut is not sensing the door is shut. Try pushing in on the door while hitting the start button.
Posted on Sep 14, 2007
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Wash cycle does not start. I push the normal wash (or any other cycle) button and a tiny amount of water flows. If I leave it alone, eventually, several lights start flashing. I have tried pressing the...
Either the hose is clogged at the entry point to the dishwasher or the solenoid vlave is bad...
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Dec 21, 2010 | Dishwashers
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Flashing lights on Maytag dishwasher
Check whether the door is getting closed fully. Try pushing little hard. If the door close switch problem it may work.
Contact service for help if u can not proceed further with electrical circuits. Micro-controller board to be checked!
May 18, 2010 | Dishwashers
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
BF162 DISHWASHER HOTPOINT
I think if you push the heated wash and heated dry button several times until all the buttoms light up this will fix your problem.
 A clean light that flashed repeatedly 7 times then off. Reset as above with the heated wash and heated dry buttons. You may then noticed a reduced flow from the pump so dissasemble the lower arm and water inlet assy.You may find it mostly plugged with foregin matter and some othe junk. Upon removal of that stuff and reassembly,It may work as new!
Feb 09, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Whirlpool 24 in. DU1055XTP Built-in Dishwasher
I don't know if your dishwasher is the same as mine, but this solution may be what you need. For electronic panel dishwashers made by whirlpool (mine is a whirlpool but with a kenmore name on it), some of them can be reset by pushing in sequence the Heated-Dry button followed by the Normal-Wash button, several times in a row. that is... Push Heated-Dry, then Normal-Wash, Then Heated-Dry, then Normal-Wash... Repeat until all lights light up. When all lights light up you can stop. The washer will then take 5-10 minutes to go through a diagnostics cycle, which is about 18-25 steps or so. You can bypass one step at a time by pushing the STart button. This may not apply to your washer, but is pure gold if it does. Good Luck!
May 26, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Start flashes and will not begin wash cycle
My dishwasher Model is 665 15891790 and the serie #FG3907905. After programing my dishwasher and pressing the start button, it fills with water, but when it is due to start the sensing light comes on. I have notice that the ring under the watering arm on the bottom of the machine seams to be cracked. Could that be the problem for the machine not starting its' cycle. Thank you.
Jul 01, 2006 | Kenmore 24 in. 16293 Built-in Dishwasher
Dishwashers Logo
449 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
