Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Model 80 get stuck between agitate and spin.
The cycle will continue on pumping out all the wash water without spinning resulting in laundry that needs to be re-spun before on to the the dryer. If I catch it right as it is happening I can cycle the door, hear a click under the drum and then it will spin out as it should. I have held the lid switch down and watched in get stuck after the agitation cycle. I was told that this could be a burned contact in my switch. I installed a new switch, but I still have the problem. Thanks for your help.
  • 1 more comment
  • christoph423 Dec 27, 2008
    Just gets bound up (motor loaded) at the beginning of the spin cycle. The water will pump out without the drum spinning. If I cycle the lid during this time, I will hear a clunk and the drum will spin as it should.
    Thanks so much for your help....Chris.
    I figured....I have been looking for a donor on craigslist.....
  • onthethejob1
    onthethejob1 May 11, 2010
    hi i need just a touch of help here....when you have lid swich down and you catch it in spin cycle do you get a loud clunk ???
  • 640 Answers
Sorry transmissions going..
Posted on Dec 27, 2008
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore laundry center model 92702 burning smell during spin and water doesnt drain
mine does this regular easy job if your desent at diy are you missing socks or wires from bra's as it probably the pump blocked take the pipe of the pump and see if there is any thing stuck in the pump remove it as long as pump not damaged should be fine probably get some loose change as well lol
Aug 17, 2012 | Kenmore 92702
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Goes thru agitate cycle then stops - no drain of water, no spin. Control dial does not advance but manual advance also not result in drain or spin. Position of dial on agitate area results in agitation.
If the drain pump is not operating correctly, the cycle will not continue. Also, sometimes the pump has something jammed in it, and may just need to be unclogged.
Sep 14, 2009 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore Model 80 get stuck after agitate and will not spin out
I have seen this on the same model recently, try lifting the lid during the neutral drain and reclose, if it engages spin then. then most likely your timer is bad too. The timer after two minutes of "neutral drain" will stop the motor (same effect as lid sw) then restart after a pause with spin/drain. this pause shifts the transmission to its next cycle which is spin. I found burned contacts in timer. Your timer list price is over $100 but easy to replace
Nov 24, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Series 90 - Model 20990902
I don't see that model # listed. Please recheck and get back to us
Feb 07, 2008 | Washing Machines
Kenmore "80 Series," model #110.28812790
Sounds like it may be in you pressure switch sounds like it is stuck on full... like you have a full tub or water..
the white part with the hose is the pressure switch
f33c358.jpgck on full... like a full load of water is in the tub
Oct 19, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
41 people viewed this question
Sal De
fordexpert
Robert Rankin
