Question about Husqvarna Rose
Embroidery unit how much does one cost?
  • Anonymous Jan 21, 2009
    did you find an unit? I need one too for the rose.
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Not sure. You might be able to find a used one -- try ebay. Otherwise, see an authorized Husqvarna Viking dealer for assistance. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 13, 2010
My Bernini 830 would not recognize the embroidery attachment. I re-attached many times, but it doesn't work.
I assume you mean a Bernina 830. If you have removed the slide-on table, I have two possible solutions. I've seen this with a couple of Viking embroidery attachment units. (I am also assuming it's not a hoop issue.)
You could have corrosion on the pins that send the signals between the embroidery attachment and the sewing machine. Remove the embroidery attachment and turn off the sewing machine. Unplug the sewing machine. Spray the pins with an electronic contact cleaner; one example is here: http://www.homedepot.com/p/CRC-QD-11-oz-Contact-Cleaner-02130-6/202262505 . Push the embroidery attachment into the sewing machine by lifting up the far side and then sliding it into the port. Remove the embroidery attachment. Repeat this a few times. (The friction of the insertion and removal will remove any dirt or corrosion.) Plug in the sewing machine and turn it on. Try connecting the embroidery attachment. If it works, remember to clean the contacts the next time the embroidery attachment isn't recognized.
Once I helped someone with two sewing/embroidery machines with an unrecognized embroidery attachment. In that case, the person swapped which embroidery unit went with which machine. The contacts were not the same and didn't mate. Once the correct machine and embroidery unit were paired, the embroidery unit was recognized instantly.
I hope this helps. If it doesn't, you may need to talk to your Bernina repair technician at your local shop.
Aug 19, 2017 | Sewing Machines
My machine does not recognize that the embroidery unit is attached. It keeps saying attach embroidery unit. Has anyone had this problem
What make and model of sewing machine do you have? I have seen this problem with a Husqvarna Viking Designer I (or similar older Viking machine). In that case, the problem was corrosion on the contacts between the embroidery unit and the sewing machine. The solution was to use an electronic contact cleaner to clean the contacts; this is one product: http://www.amazon.com/CRC-05101-QD-Electronic-Cleaner/dp/B000CCMLD0 . Make sure that the machine is unplugged. Spray the contact cleaner on the contacts. (In some cases, you should then connect the embroidery unit to the machine and remove it a few times.) Allow the product to dry before you plug in the sewing machine again.
In another case, the solution was actually easier. The owner had two similar embroidery machines. She managed to mix up which embroidery unit went with which sewing machine. Neither embroidery unit could be properly seated on the machine that she attempting to use it with. Once the embroidery unit was paired with the correct machine, both pairs worked.
I hope this helps.
Aug 03, 2015 | Sewing Machines
Do feed dogs drop automatically on SE-400 when embroidery unit is attached?
Yes they should unless the tab on the middle of the embroidery unit is broken.
Jul 31, 2014 | Brother SE-400 Sewing & Embroidery Machine
The embroidery unit no longer registers on my artista 180 when I connect it. I borrowed a friends embroidery unit and it worked so i assume it not the 180 which is the problem. What should be my next move...
If you bought the embroidery unit with the machine, I would try to take it back to the place of purchase & ask for a sewing tech to check the machine & unit for you.
I recently had a similar issue with my machine-took it to a local bernina agent & within a week, it was back in my sewing room, at no cost to me. I hope this helps you, & yes I have a 180 with the embroidery unit like you mentioned
Jan 05, 2011 | Bernina Artista 180
Embroidery arm won't park or go in position on hoop to embroider
You may need to have the embroidery unit serviced. The slide rods in the embroidery unit will get dirty over time and must be cleaned and lubricated. If not, the mechanism can not slide freely and you will be unable to keep the unit calibrated while stitching a design.
You could attempt to disassemble and clean it yourself, but if you bring it to a repair center in pieces or improperly assemble your repair is going to cost a lot more than it will if you go today.
Apr 19, 2009 | Husqvarna Designer I
DISNEY BROTHER SE-270D COMPUTER SEWING & EMBRIODERY
but is the carriage moving,? if not disconnect and try to connect again, the embroidery hoop holder usually moves to check itself, if it still does the same thing the connection that goes onto the machine is not making a proper connection, I also had this problem, with a 2100 brother , I fixed it by using a crochet hook and just tightening the connection that connects to the machine on the embroidery unit, but tread very carefully it just takes a slight move. if this fails it will have to be adjusted cost is usually $100au
Sep 10, 2008 | Brother LS-2125 Mechanical Sewing Machine
The carriage of the embroidery unit is not move automatically to the embroidering standby position.
Is the need in upright position ?
or have you fitted the embroidery hoop correctly.
If all else fails switch off and start up again - should then automatically go to correct position.
May 16, 2008 | Singer CE-200 Quantum Futura Computerized...
Problems with embroidery unit
The machine should always be off when you attach the embroidery unit. Attaching it without it being turned off can damage the computer system of the machineor embroidery unit. It needs to be tested by a repairman.
Feb 19, 2008 | Bernina Artista 180
Will a Husqvarna #1 Plus embroidery unit work on a Husqvarna Rose machine?
I am sorry to inform you that Husqvarna # 1 embroidery unit does not fit onto the Rose machine. The terminals on the Rose is upright, while on the H # 1 it is flat. If you want to do embroidery on the Rose, you will have to purchase the embroidery unit.
Sad but true
Jan 20, 2008 | Husqvarna Rose
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
