I CAN'T GET THE TAPE DOOR TO OPEN
WHAT TO DO???
Try removing the battery. While holding the eject button, re-insert the battery.
Testimonial: "PERFECT..THANK YOU BRILLIANT PERSON(ARTHUR ALDRICH!"
You need the battery to operate the tape eject. Don't try to pry out the trim - the door will break off!
Try to replace the battery and then go through the eject procedure.
Another idea. Try the a/c battery adapter to power the unit. I assume it plugs into the camera someplace. If you don't have one, GENTLY try to remove the battery. Clean the contacts with a pencil eraser and replace or recharge the battery. That should make the tape mechanism work. Try forward, reverse, ff and rewind. Then try to eject the tape. The battery is meant to come out easily and can be coerced. The tape door cannot.
NO I AM AFRAID IT DID NOT
BUT I DID BREAK A NAIL I'VE BEEN TRYING TO GET AROUND TO TRIMMING
ANY MORE SUGGESTIONS
OH FORGOT TO TELL YOU THE BATTERY IS DEAD
DOES THAT MATTER
SEEMS TO BE STUCK AT THE BOTTOM
