Installed a new motherboard GA-8SIMLH NEW GRAPHICS CARD 64 BIT AGP MY PROBLEM IS HD LIGHT IS ON TEMPATURE LIGHT ON ALL FANS WORK AND GET NON STOP BEEPING AFTER A MIN OF BOOTING.
    Sergeant:
  • 302 Answers
Update your bios and you can go to setup when you turn your computer on and you can turn off the motherboard audio
Posted on Dec 06, 2008
Tip
DELL Inspiron 15
for those who have a DELL Inspiron 15 and have problems with video cards
Intel HD Graphics 4000 and AMD Radeon HD 7670 and WIN 7 x64 operating systems
I recommend this link where to download the compatible drivers and it works.
at first glance if you download from the manufacturer's website amd drivers it will show two video cards Intel HD Graphics 4000 and AMD Radeon HD 7670 but these drivers do not work and AMD motherboard because the screen turns on and off without interruption.
I downloaded from this link other drivers>
http://delldriverdownload.net/inspiron-15-3521-windows-7-64-bit-drivers/?id=4884
AMD Graphics Driver for Inspiron 15 3521 Windows 7 64-bit
and after installing everything was perfect and the manager appeared on these devices video cards Intel (R) HD Graphics 4000 and AMD Radeon HD 7670M
before this oprate uninstall any previously installed driver and reboot without permit automatic installation of drivers.
download or perform manual operation.
I hope to be helpful.
Success.
AMD Graphics Driver for Inspiron 15 3521 Windows 7 64 bit
on Nov 11, 2016 | Miscellaneous
When i connect my graphics card to my pc i get a black screen there is no beeps and i cant even hear an windows sound. when i disconnect my gpu my pc works fine i have tried to disable onboard graphics...
Hello xvanpersiex, these are "Full Specifications" of your [Graghis Card].
"Check this to the 'Specs' of the "Motherboard to see if it 'Supports' the Graphic Card?"
"Try 'disconnecting, and reconnecting' the "Graphis Card"
Verify that 'all' the "Connections" are "Tightly Inserted."
*Go to the Control Panel > Device Manager > AGP Graphic Card > Verify Installed? >
Update Driver! > Restart Computer"
"If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9"
ATI Radeon X1650Pro (AGP 8x, 512MB) General
  • Device Type Graphics adapter
  • Enclosure Type Plug-in card
  • Vista Capability This graphics card is capable of running the new Aero interface featured in Windows Vista Home Premium and higher.
  • Interface Type AGP 8x
Processor / Memory
  • Graphics Processor / Vendor ATI Radeon X1650 Pro
  • Graphics Card Performance This card's graphics processor and memory mean that it is not recommended for most games, but it will still be fine for office applications and other normal computing tasks.
  • RAMDAC Clock Speed 400.0 MHz
  • Video Memory Installed 512.0 MB
  • Technology DDR2 SDRAM 128-bit
  • Features Avivo Technology
Video Input
  • Type None
Video Output
  • API Supported OpenGL 2.0,
    DirectX 9.0
  • Max Monitors Supported 2.0
  • TV Interface HDTV out
  • Analog Video Format S-Video,
    Composite video
  • Digital Video Standard Digital Visual Interface (DVI)
Expansion / Connectivity
  • Interfaces 1.0 x DVI-I (dual link) - 15 pin HD D-Sub (HD-15),
    1.0 x HDTV output - 29 pin combined DVI,
    1.0 x VGA
  • Compatible Slots 1.0 x AGP
Miscellaneous
  • Microsoft Certifications Certified for Windows Vista
Software / System Requirements
  • OS Required Microsoft Windows XP,
    Microsoft Windows XP Media Center Edition 2005,
    Microsoft Windows XP 64-bit Edition,
    Microsoft Windows Vista
  • Recommended Power Supply 350.0 Watt
  • Peripheral / Interface Devices CD-ROM
Feb 22, 2011 | ATI RADEON X1650 Graphic Card
Wont start monitor
The Gigabyte GA-8PE667 Ultra MB will only run certain AGP graphics cards. Check you manual. See page 1. Click the next link to open your manual; http://europe.giga-byte.com/FileList/Manual/motherboard_manual_8pe667u_e.pdf
To view your manual you'll need the program, Adobe PDF reader.
You can download Adobe here; http://www.adobe.com/products/reader/
If you install anything other than an AGP 4X, (1.5Volt) graphics card. Your system may not boot up normally, if at all. Just because you tested your graphics card in another system does not mean the card is compatible with the GA-8PE667 Ultra. The link below will show a compatible graphics card for your Gigabyte GA-8PE667 Ultra;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3281698&csid=ITD&body=MAIN#detailspecs
Cheers!
Mike
Nov 05, 2009 | Gigabyte GA-8PE667 Ultra Motherboard
Cannot install manufacturer driver
does the card support 64 bit windows ? their are a lot of issue using 64 bit windows
Mar 24, 2009 | Chaintech XGI Volari V3, (128 MB) Graphic...
Will it work with Agpx4 motherboard ?
After looking at the motherboard and video card you specified,
Agpx4 Ga-7zx-h Motherboard
GeForce FX 5500 Video Card
The video card requires a AGP 8x slot and the motherboard only supports a AGP 4x.
Feb 01, 2009 | Point of View GeForce FX5500, Graphic Card
Geforce 2 MX-400 (64 bit) with vista
Before you installed the Geforce graphics card was your monitor connected to a video output on the motherboard?
If this is he case you may have to disable the onboard video card from the BIOS.
You can check by swapping the monitor's video connector between each of the video outputs.
If Vista detects a video card and you had not installed the video driver, it would install standard VGA driver, you can then install the Geforce driver.
Jan 02, 2009 | Gateway GeForce2 MX400, (64 MB) AGP...
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
