Question about Canon PowerShot A70 Digital Camera
Canon A70 stays in replay mode
On turn on lens now doesn't move. always stays in replay mode regardless of switch position. tried a spare rear switch pcb and rear cover - same problem. Helppppppp! any actual repair advice (inlc. diagrams if available) will be very appreciated. I'm quite technical-wise. Thanks for your consideration, Gerry.
  • Gerry Gerry
    Gerry Gerry Feb 16, 2007
    Thanks a lot Joe - I gently flicked the the little white flex pcb mode "switch" "lug" and it came out to it's normal perpendicular position. Reassembled and all working again! This may help others too. Thanks for your very helpful and clearly knowledgable input. Regards, Gerry.
    Sniper:
  • 80 Answers
Gerry, The mode switch is a very common problem that causes the camera to remain in either play or camera mode. The stem breaks off the top of the switch and no longer functions. If this is not the case, the flex harness (operations unit) can get torn on top if the camera has been dropped. If the switch appears to be good, check for ground switching between the two outer legs of the switch, the micro gets a low signal from the mode switch to determine what state the cameras in. Good luck, this is a nice camera! Joe Weibel Custom Electronics (customelectroncis.org)
Posted on Feb 13, 2007
  • Joseph  Weibel
    Joseph Weibel Feb 16, 2007
    Your welcome Gerry, it's nice that this worked out for you.
    Joe
Playback switch does not operate
PDF]Camera User Guide
gdlp01.c-wss.com/gds/7/0900011217/01/PSA520510CUG-EN.pdf
Switching between Shooting and Playback.....32 .... Please note that Canon digital cameras are intended for personal use and should never be used .... Do not operatethe flash with dirt, dust or other items stuck to its lens. ..... PowerShot A520:.
Repair tips for digital cameras that won't power on. 'Do It ...
camerarepair.blogspot.com/.../simple-fix-for-dead-cameras-that-wont.ht...
Nov 30, 2007 - It was a fix for a Canon A520, but am not sure if it would work for ..... I have a Canon Powershot A540 which will not turn on and lens is stuck out extended.... (even when they are new) in camera mode and not playback mode.
Digital Cameras - Canon PowerShot A520 Digital Camera ...
Dec 02, 2015 | Canon PowerShot A520 Digital Camera
Power Shot A70 will snap pictures but there are no images in the monitor and replaying mode shows only red light image taken. I am still able to view past images taken but can no longer see or take...
This sounds like it might be a defective CCD imager, and is a known defect for your particular model camera.. If so, Canon should fix this for you for free if you live in the US, Canada, and a select few other countries. If you live outside the US, contact Canon support for your country to see if they'll still honor the advisory (some still will, especially if you stress you knowledge that this is a known defect of the camera). They may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please see this link for more info.
Feb 07, 2011 | Canon PowerShot A70 Digital Camera
My canon 20D autofocus doesn't work... can you tell me haw to do?? thanks..
Make sure your camera is set to Auto mode (top left knob). Check your lens and make sure it is switched to "auto" and not "manual"(sliding switch near base of lens). Make sure your lens can rotate and move without being obstructed. Clean the lens contact by removing the lens and use 99% alcohol or lens cleaner sparingly to clean off the metal contacts.
You can also check your viewfinder focus, it has a small dial upper right, that you can fine tune to focus to your own eyesight. If it is way off, your view will always appear to be out of focus.
Hope that helps.
Dec 29, 2010 | Canon EOS-20D Body only Digital Camera
LDC Monitor remains black. Have reset the default
Affected cameras with this problem include: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Jul 08, 2010 | Canon PowerShot A70 Digital Camera
I TURN ON MY A70 AND I GET A VIEW OF THE LAST PICTURE I TO TOOK.
The camera is stuck in picture review mode. Try sliding the mode switch back and forth a couple times, and leave it in camera mode to see if this corrects the problem.
Apr 02, 2009 | Canon PowerShot A70 Digital Camera
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
Canon digital
First make sure that your lens is clean. Turn the camera on and look for fingerprints on the lens. If so, clean the lens with soft tissue. But if the lens is clean, then this sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info: http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Nov 03, 2007 | Canon PowerShot A70 Digital Camera
Viewer mode is not working
The CCD is on the fritz. Go to canon website, there is a bulletin and they will repair regardless of age
Nov 01, 2007 | Canon PowerShot A70 Digital Camera
Can't take a picture or even see an image in picture mode. I get an error message E18? I am able to look at photos taken in the past.
SkiPowder, the E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
Guest has a different problem. Guest's problem sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your cameras warranty status. Please check the following two links for more info:
Oct 31, 2007 | Canon PowerShot A70 Digital Camera
Canon PowerShot A70 Digital Camera Logo
112 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
