Question about Samsung L100 Digital Camera
I bought samsung digital cam L100 but when i started taking more then 4 pictures msg of MEMORY FULL appears on the screen i want to know that is there no any builten memory card inside the camera whats the reason behind it ????
  • 2 more comments
  • Anonymous Dec 26, 2008
    Dear Sir,
    I have the same problem with my new samsung camera, it takes 4 pictures the says Memory is full, there is no Memory card in the camera,
    any help will be very welcome,
    from keith
  • caz10 Dec 29, 2008
    memory full appears after 4 shots and dont have a memory card inside
  • Anonymous Dec 29, 2008
    i have the very same problem
  • janelg Jan 05, 2009
    I have the same problem, no memory card, changed the pic quality and it allowed me to take 1 more picture. What is the lowest setting to allow you to take pictures all day. Must admit the disk i received with the camera is mind blowing.
My L100 cant on... n sound beep 3 times..
why?? is that any problem coz of virus or batery ?
-fiznis-
Posted on Aug 15, 2009
To fix this problem you must have a memory card. If you don't have one, you can change the picture size, to change it, you click the "Fn" button on picture mode, and change the size, and quality.
Hope this helps.
Posted on Jan 09, 2009
If you reduce the size of pictures to the minimum you can shoot about 30 pics on the internal memory, and enlarge them once transfered to a pc or lappy if you wish, The default setting is set to the largest size photo and is rather a stupid set up from Samsung. However, a 2 gig SD card costs around £6.00 by mail order from a number of sites and will hold hundreds of pics, Unless you are David Bailey it would be hard to exhaust the memory. Happy shooting, its a nice little camera, and apart from its default memory it has many features found on more expensive cameras.
Graham
Posted on Jan 05, 2009
    Novelist:
  • 170 Answers
Have you initialized the memory card? Initializing will clear it and allow it to accept new pictures.
Posted on Dec 06, 2008
I have a samsung l100 cam.but my cusine destry the lens.so what can i do please say..........................
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 25, 2011 | Samsung L100 Digital Camera
LCD screen comes on for about a second, lens extends then detracts at the same time then there are 3 distinct beeps then goes off. Full battery.
did you drop it? water damage?
if not, its a memory card or main board problem..
i hope youre under warranty...
take it back, or try the memory card in a different cam
Feb 17, 2010 | Samsung L100 Digital Camera
I took about 4 pictures and my camera is saying memory full im guessing something is wrong with the memory card? Do i need to get a new one
If is the memory card that came with it, it is most certainly of a small capacity: 16 or 32 MB. If you did not buy a higher capacity card then that is the reason memory is full.
Hope it helps
Sep 06, 2009 | Samsung L100 Digital Camera
Digital camera
personally i never connect the cam to pc using the usb cable, i take the memory card out and put it in an sd card usb adapter, you say the images are protected, this tells me that you have the lock switch activated on the sd card...hope this helps :)
Jul 11, 2009 | Samsung L100 Digital Camera
Card error on L100 samsung camera, help please.
copy all the pictures/files saved in your memory card to your PC then format the card, you can format the card by going to MENU > SET UP > FORMAT
make sure that you have a copy of the files in the memory card because formatting the memory card will erase all the files that are saved in it.
Mar 04, 2009 | Samsung L100 Digital Camera
Samsung L100 digital Camera
remove the memory card and slide up the lock at the side of it
Jan 28, 2009 | Samsung L100 Digital Camera
Accidently Formatted Memory Card on Samsung L100
if u have a pc then try looking on your memory card
u formated your card in your camera
u could try to reformat it
Jan 22, 2009 | Samsung L100 Digital Camera
Memory full
depends on the cam
and it is the size of the pic and the good the pic is
eg ;
2x4 - 2 gig = 150 pics
2x2 -2 gig = 500 pics
Jan 16, 2009 | Samsung L100 Digital Camera
My samsung l100 memory is full after 4 photo ? i have no memory card
you have your "picture size" set too large. In the pic settings you can change it to take more or less pictures, depending on the quality you want. A better photo will take more memory. If you don't want to print your photos, put your setting on smaller size, and you will be able too shoot all day.
Dec 29, 2008 | Samsung L100 Digital Camera
Samsung l100 silver can be used as web cam?
this particulat model cannot be used as a web cam, when you connect it to your computer it is detected as a removable device not an imaging device
hope this helps
Dec 25, 2008 | Samsung L100 Digital Camera
Samsung L100 Digital Camera Logo
161 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
