Drive for a few minutes and it overheats - water overflows out of radiator
SOURCE: 99 cadillac deville engine overheating an loosing
Check to see if you have flow through the entire radiator.If part of the radiator core is cool to the touch when the engine is at operating temp, this indicates restricted radiator flow. If the entire radiator core is not allowing water to flow through, cooling will not be at all efficient. Also a good idea would be to purchase a block tester. available at napa and other reputable parts houses for around thirty dollars. You remove a small amount of coolant, and put the tool in the radiator, or pressure tank opening. If there are any combustable gasses present, i'e' exhaust, this would indicate a head gasket breech, (or maybe worse) and would indicate that it's time to stop looking for a simple problems, and get proffessional help. Good luck to you!
SOURCE: 96 jetta overheating
there is sensor in the bottom off the rad that controls the cooling fan is it operating kdc744
SOURCE: 95 honda civic lx overheating
COULD BE COOLANT SENSOR,HEAD GASKET,CHECK THE TIMING,THE PROPER MIXTURE OF COOLANT,WATER PUMP.DID YOU HAVE IT CHECKED OUT?ANY LEAKS?HEAT WORK WITH FAN?
