A) Clean the optical eye of the CD/DVD burner. If the laser optical is dirty it won't read disks.
The laser optical eye is located in the bottom of the CD/DVD drive.
You can,
1) Turn the computer on, open the CD/DVD drive tray, and then turn the computer off.
Unplug the computer from power.
Use a can of compressed air for computers, and spray towards the bottom.
After you are satisfied the optical eye is clean, let the computer sit for 3 minutes.
Then plug into power.
Open the drive, try a disk.
2) Use an optical cleaner disk. The disk usually has small brushes on it, which you are to properly apply a few drops of cleaner to.
Then the drive tray is closed, and the disk does it's job.
There are many variations of disk cleaners, the above is just one example.
B) You may have driver problems.
A Driver is a small piece of software that the Operating System uses to 'communicate' with a device.
{Windows XP is one example of an O/S. A CD/DVD drive is one example of a device}
Sometimes Windows is a 'funny animal'. Files tend to be corrupted. A Driver file may be fragmented.
You have to 'slap Windows around' a little bit.
1) Left-click on Start, then Right-click on My Computer. (Windows XP)
2) Left-click on Properties at the bottom of the list.
You are now looking at the System Properties window.
3) Left-click on the Hardware tab at the top.
4) Left-click on Device Manager in the middle.
5) When Device Manager loads, left-click on the + sign next to > DVD/CD-ROM Drives.
6) Right-click on the drive's name.
7) Left-click on Uninstall.
A Microsoft 'squawk box' will come up.
"Warning, you are about to uninstall this device, ya-da, ya-da"
Click on OK.
(It is Ok)
8) Now close all windows, go back to your desktop screen only.
9) Turn your computer off. WAIT 1 minute, then turn your computer on.
After Windows loads you should see a pop-up of of the system tray at the bottom of the screen,
"Found New Hardware", and perhaps another pop-up after that, "Found XXXXXX CD/DVD drive"
If your CD/DVD drive doesn't work now, I suggest it's tiem to buy a new one.
Mechanical devices in a computer are rated in hours of usage, and your optical drive, (CD/DVD drive) may be at the end of it's 'Life-span'.
Example,
http://www.amazon.com/Notebook-Burner-Drive-Latitude-Optiplex/dp/B0042WQ3QCDell Inspiron E5400 Service Manual from Dell Support,
http://support.dell.com/support/edocs/systems/late5400/en/sm/index.htmClick on > Optical Drive on the right side.
Regards,
joecoolvette
