SOURCE: Dell Optiplex GX520 message:
Hey,
there is a 3 volt flat battery inside the computer, it in most cases clearly visible.
Replace it with the same type of battery, then adjust the clock in the system setup.
All done, all fine.
Let me know if you need anything else.
Thanks,
Ekse
SOURCE: Bios default password
The BIOS default password is just blank, and it is not asked.
When you set a bios password, you are asked to enter a value, therefore if bios is asking the password, the password had been changed.
To reset the bios password if you do not know the password you need to access to motherboard and temporarily remove battery for few seconds.
Removing battery will reset bios and delete the password.
Unplug power cord before accessing the motherboard, and try not touching the motherboard with your finger.
Put battery back in place before restarting computer.
See also the following websites:
technibble.com/..
satyathakur.com/blog/
SOURCE: Dell OptiPlex GX520 PC Desktop Problem
Hello everyone, check your cpu - I've just had one of these in for repair and the cpu was faulty - removing the ATX 4way 12v lead let the pc start rather then detecting a short and shutting the psu down. Changing the cpu cured the fault.
Thanks
SOURCE: My Dell Optiplex GX520 will not boot. There is no
If 1 & 2 are off ... then you have problems.
Memory modules are detected, but a memory failure has occurred.
According to Dell's notes:
Their remedies are:
SOURCE: Dell Optiplex GX520 PC won't boot - power light at
OK the first step is to remove the side of the case and check that all the leads are firmly inplace. - If this does not fix it post a comment.
