Question about Kitchen Ranges
When I go to start the barbeque I have to unhook the tank everytime to get the gas to flow from the tank to the grill.
    New Friend:
  • 57 Answers
You need a new regulator. These can be purchased and Lowe's, Home Depot, or your local propane supplier. (the ones at your local propane supplier will be of better quality and adjustable.)
Posted on Dec 06, 2008
Grill isn't flowing propane when tank is on. No smell of propane and starter is clicking. Tested 3 tanks on grill and no luck. Tested same tanks on another grill and they work fine so it's the
it could be the reg or a blockage in the line or open the taps on the grill then close them reconnect gas tank open slowly then tis if there is gas to grill
Mar 16, 2012 | Barbeques Galore Turbo STS 3-Burner...
Flame is low ... no pressure
It probably is not the grill. The problem on the low pressure is the new tanks have a touchy safety feature which stops the flow of gas from the tank if the valves are opened too fast. Try this:
Remove the tank from the grill and open all the valves. Close all the valves and re install the tank. The SLOWLY open the tank just a quarter turn and retry it. MORE HERE
Jan 24, 2011 | Barbeques Galore 52-inch Grand Turbo...
Gas will not flow to burner to light grill?
could be the reg on the tank , not working no flow of gas ,
May 15, 2010 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
The new style OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
Mar 28, 2010 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
There is a high pitch that people over approx age 30 cannot detect. My son and daughter complained of a high pitched noise coming from our gas grill, but I could hear nothing. I turned the gas tank off,...
What they are hearing is the regulator. There is a diaphragm in the regulator that is vibrating due to the rush of gas flowing through it. This is easily corrected. First, the next time you light the grill, turn the tank valve only one quarter to one half of a turn and light the grill, once the grill is lit, if you have trouble bringing the grill to the temperature you want, you can open the tank valve more and the noise shouldn't start. The reason the noise won't start then is because by that time, the regulator's diaphragm is at the temperature of the gas flowing through it and, subsequently, will not vibrate. If the noise starts again, you can go to just about any home improvement store and get a replacement regulator.
Nov 18, 2009 | Kenmore 16322
Low flame only 2 burners will light inition seems good new tank of fuel
try opening the tank valve really slow. it you open it too fast it restricts the gas flow.,
Oct 10, 2009 | Barbeques Galore Grilling
Gas is not getting to the heating elements - i checked them and they are all clear of clogs and my propane tank is full - any idea what could be going on?
try opening the tank really slowly. if you open it too quickly the overfill protection devise in the tank will restrict the gas flow to the burners. hope this helps.
Sep 26, 2009 | Barbeques Galore Grilling
BBQ Galore Capt'n Cook 4 burner gas grill won't get hot.
Most modern gas regulators have a safety feature to prevent gas left on. If you shut off the tank first and then turn off the burners, it will trigger and keep the gas flow at a very reduce flow to prevent you from turning on the tank again with the burners left on and not realizing it. Turn everything off and then turn on tank first, followed by the burners and this will solve most problems of a low flame or a bbq that won't get hot.
Dec 05, 2008 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Regarding gas Barbeque and charcoal Barbeque
It depends on your preferance
Charcoal most say it gives what your cooking better flavor but the disadvantage is waiting for the coals to get hot and longer cooking time due to less heat.
Gas quick cooking time, quick warmup time the disadvantages scrafice some of the flavor, unless you buy a gas grill set up to smoke it is almost impossible to use a conventional gas grill for smoking, and also you have to have enough gas to cook completly or have a second tank in case you run out.
Hope this helps Ya
please rate me
Jul 20, 2008 | Barbeques Galore Capt'n Cook 3-Burner...
Kitchen Ranges Logo
80 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
