Phillips cdr778 approximately 4 years old, suddenly will not "recognize" an external source to record...please help.
  • 112 Answers
SOURCE: Phillip CDR778
You can try other brands of audio cdr but it sounds like your laser is on it's way out. Some find cdrw's still work after cdr's have stopped being recognised.
Posted on Jan 22, 2008
shaggyrat
  • 1224 Answers
SOURCE: phillips cdr 785 audio recorder
time to buy new one or upgrade software
new cd/dvd formats came out maken it hard to play record or watch on outdate equipment
they remolded the cd/dvds with a new gloss
Posted on May 13, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Phillips gogear is frozen
Press and hold the Power On/Off key and the Volume + key for a couple of seconds to reset
If that alone fails, run a Repair in the Philips Device Manager
-Tha Mp3 Doctor
Posted on Dec 31, 2008
TOM2-TOM2
  • 110 Answers
SOURCE: Phillips HDTV will not turn on I have a 3 year old Phillips 51PP9100D/37 TV that worked gret up until a week ago.After being turned on for a short peroid of time it just shut off.I have no pic. or sou
Check fuse #1003 on SSB and Audio Ouput IC #7700.
Posted on May 27, 2009
JulesPCaut
  • 702 Answers
SOURCE: USB not recognized
Sometimes it helps to reinstall the drivers for the USB hub/controller in the Device Manager.
For other ideas, have a look at these external HDD troublshooting tips.
Hope it helps.
Jules
Posted on Jun 13, 2009
My Phillips CRD778 always tells me that i need an Audio CD. I have tried everyCDR and W and it still tells me the same thing. Can this be repaired?
Did you read the manual? The words DIGITAL AUDIO must be printed on the blank medium or it will not record to it. Find some. Try eBay.
Sep 20, 2011 | Philips CDR778 2-Disc CD Recorder
I have a brookstone brand record player with the ability to convert records to mp3/wma files via a sd slot and a usb slot. Every time I plug in an empty flash drive/ usb toward an external hard drive, or...
External drives require to be formatted before use on somewhere else..
Pls "format" it on your Pc and than try again....
Sometimes proper formatting is possible on the equipment itself (like Digital Cameras )
I was not able to get into your units detailed specs to see if such feature is existed..
if its exist ,you must access thru "set up menu"
Secondly ,if the display recognizes the HD than your Record player will create its own Files/ folders..try to record something even it reads "no file" and than plug it into your PC to see what has been recorded..
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 24, 2011 | Audio Players & Recorders
I have connected my phillips cdr785 recorder the proper way to record from an external source and I get the message "start source" on the cdr side when trying to record. And it never starts...
If you're recording an analog source the recorder won't automatically start. You have to start it in sync with the playback.
If you're trying a synchronized digital recording...
Page 28 of the manual says
Start playback on the selected source.
The CD recorder starts to record simultaneously and recording in progress is shown. The remaining recording time left of the CDR(W) is displayed.
Note: If you start playback on the selected source within a track, recording starts at the beginning of the next track or after 2.7 seconds of silence in analogue recordings.
Mar 05, 2011 | Philips CDR785 3-Disc CD Recorder
Does the unit recognize 80 minute discs?
Any desk CD recorder will only recognize discs labeled "Audio Disc".
That means you cannot use CD-R or CD-RW discs, that are basically data discs. No matter duration, if your 80 minute disc is CD-R or CD-RW, your unit will not recognize it. Good Luck.
Flavio/BRAZIL
Jul 25, 2010 | Philips CDR778 2-Disc CD Recorder
External HDD no longer recognized by new win7 PC
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
PHILIPS CDR778
My CDR778 display reads OPC ERROR .How do I reset it ?
Mar 06, 2008 | Philips CDR778 2-Disc CD Recorder
Phillip CDR778
Dec 29, 2007 | Philips CDR778 2-Disc CD Recorder
Recorded finalized CD's will not play on standard CD player
Are you using the same brand of discs you used to? Do they palyback on the machine in both the record and the playback deck? Do your old cdr's you recorded still play in the standard cd player? You can try the diagnostics - hold down the 'play' and 'fwd' keys on the record side as you power it on.
Oct 31, 2007 | Philips CDR778 2-Disc CD Recorder
Record mode
Hi everyone! In reply to my own question.The answer was operator error,not knowing the operation of the unit.It was due to the incorrect timing of the input source to be recorded.Everything ok now.
Mar 05, 2007 | Philips CDR778 2-Disc CD Recorder
My CDR778 screen is in Japanese now?!
Try entering the service diagnostics to reset - hold in play and fwd on the record side as you power it up.
Jan 04, 2007 | Philips CDR778 2-Disc CD Recorder
 Grubhead
Grubhead
