Question about Microwave Ovens
F9 Error I read your June 2008 response to fixing the F9 problem. I have a Kenmore Elite Ultra Wave Microwave Hood and it is displaying the F9 error.  I listened for the ticking and it is there which you indicated then is the Magnetron.  Do you know where I can buy that and how to replace it?  Please respond to shih76@yahoo.com. Thank you.
  • jhn_reese Dec 29, 2008
    We have a Kenmore elite microwave and it runs for a few seconds then displays the F9 message. Any solutions? Sears parts direct says they have no parts for this model.
  • chandrakhan Apr 16, 2009
    Receiving an F9 error code on a Kenmore Elite Microwave Hood Model 721.63684.
    Why can't they build appliances that last more than 5 years without needing a repair?
  • Microwave Ovens Master
  • 9,030 Answers
You can find exploded views and order parts by entering your model number at the Sears parts site.
Posted on Dec 08, 2008
What does the code F9 means on a Kenmore Elite Microwave oven model 721-62362 manuf on March 2003
The F-9 error code indicates a defective control board, inverter or line voltage too high.
Read more: http://wiki.answers.com/Q/What_does_the_code_F-9_mean_on_a_Kenmore_Elite_Microwave_oven#ixzz1FMSrTmbU
Hope that answers your question and it won't be too expensive.
Check on ebay for prices.
Mar 01, 2011 | Kenmore Microwave Ovens
Kenmore Ultra Wave Microwave has no power
after removing the cover of microwave chk for continuty of cavity thermostat usually calld TCO(thermal cut off). it is located on top of the cavity and circular in shape.usually neutral wire goes through this 2 control board and this TCO is for protection of cavity from overheating.if this tco is open.then replace it.usually this happens when u cook for 2 long.
Aug 15, 2009 | Goldstar MV-1515 Microwave Oven
9Fp and microwave cuts off
F-9 means the inverter board has failed. A bad magnatron can also cause this code. Recommend replace the Mag. and inverter board.
Feb 27, 2009 | Kenmore 62622 Microwave Oven
F-9 Error code
The F9 error code indicates a failed inverter. If resetting the unit does not help you will need to have the inverter & harness checked.
http://media.fotki.com/1_p,wbgdfgsrsttwqwbxgtqsskgwtqkq,vi/kgdfkfrkkxkfdtftrfb/1/1303472/5961857/image45625img-or.jpg
This can sometimes by caused by a power surge or glitch through the electrical lines.
You can sometimes clear this fault by completely unplugging the microwave for 1 minute.
Plug it back in and see if the fault code returns.
If it does, then you have an internal component failure that will need to be serviced by a technician.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances.
Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged.
A microwave radiation leakage test must be performed on the unit following any internal component repair.
It does not ALWAYS indicate a inverter control board problem however in other brands/models.
LG's service manual (for an example) suggests the f-9 code could be due to line voltage, magnetron, inverter module, "Relay2", or a loose connection between door/magnetron/control pcb.
Other indications might help narrow down these choices before having to pull out your multimeter and crack open the microwave case.
For example, if the microwave works, but heats slowly, then the troubleshooting manual narrows your choices down to magnetron or line voltage problems, and pretty much rules out the other possibilities.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 17, 2009 | Kenmore 80809 Microwave Oven
Kenmore ultra elite microwave hood combination
F9 code can mean something different depending upon the particular model.....
1.) IF your Microwave uses "UltraWave technology"/"SmartWave technology"...Then either the Magnetron has failed or the Inverter board has failed OR maybe the control board has failed (HUH?).
2.) IF your Microwave does NOT use "UltraWave technology"/"SmartWave technology" then one or more of the door switches has failed.
** "UltraWave technology"/"SmartWave technology" **
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
Note: This 'technology' may come in other flavors as well
Jan 19, 2008 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
621 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
