How do i plug a dvd player into a RCA television model F19261?
    New Friend:
  • 57 Answers
The same way you hook it up to an RCA television model F19262
Posted on Dec 06, 2008
How do I connect a DVDs player to an older model television
you can buy a little box at Walmart Bestbuy or radio shack. you just plug i the RCA cable into it and then run the coax cable to your TV and plug it in to ac wall outlet. some handle more than one RCA plugs so you can ad tings like game systems.
Nov 29, 2014 | Televison & Video
How to tune up dvd player
  • Plug the power cable of the Samsung VHS/DVD player into an available power outlet near the television.
Connect a set of RCA audio and video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. The colors of these cables are yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to the color-corresponding inputs on your television. When plugging in these cables, look for a label for the input, such as "Video 1" and "Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step 3. If you did not take note, you can also tune through your television's input channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Component Video
Connect a set of component video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. These cables will look similar to composite audio and video cables, but they are instead color-coded as red, blue and green.
Plug the other end of the component video cables into the color-corresponding inputs on your television. Take note of what input number you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your VHS/DVD player, then connect the other ends to your television. These cables are color-coded as red and white and must be plugged into the same input number as the component video cables.
Tune your television to the component video input channel where you connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Jul 10, 2012 | 2005 Toyota Caldina
Cannot find the audio/video in connections on an rca f19261 tv.
The only solution to your problem if the tv does not have rca inputs is to optain a converter thant converts coax to rca........ but if the tv has an svideo input that would work as well with a mini to mini audio plub
Sep 05, 2011 | RCA F19261 19" TV
I am having no luck connecting a DVD player to this RCA TV/VCR Combo model T25062 even though I am plugging into the correct audio/video outlets? Is it not compatible with a DVD player? Any suggestions? ...
Just to make sure, red/wht is for audio, and the yellow is for video. other then plugging them in you will most likely need to go thru the menu system and find the right location to except the feed from the dvd player.
Mar 08, 2011 | RCA T25062 25 in. Combo
I'm not very techy when it comes to hooking up my model # 2603 flatscreen to my curtis model #1043 DVD player.........HOW DO I PLUG IN THE RIGHT WIRES......Please help. Thanks, TOM
RCA Plugs Wires. If you use only Audio, just plug the red and the white plug into the designated jacks. From the recorder you might need a 1/8 Stereo Plug. If you have RCA outputs, no problem, if it's a DVD player, than you need an RCA plugged wire with a yellow plug. Just to keep them apart. So you connect the input wire to the correct jack on the KCR2610.
Jan 24, 2011 | Curtis KCR2610 7 in. Portable Television
How can I connect my vhs player to my insignia tv? It already has a built in DVD player? I've tried the tri color cords but they don't work.
I would need to know the model number of your TV to be sure. But the RCA plugs should work (tri-colored cords... Red, White, Yellow typically) But if it's a combo TV/DVD player... you probably need to change the input to AUX1 or whatever the tri-colored RCA jacks are plugged into... and not on DVD setting. Try that. and advise back!
Oct 12, 2010 | Insignia Televison & Video
I've hooked up my dvd player to my rca television
Did the dvd Play? if yes, Maybe you have to select in the VIDEO mode on your t.v. not in the CHANNEL Mode. Because you cannot watch video in channel stations unless otherwise you have RF tuner. or the rca plug is faulty???? Try another rca
Mar 20, 2009 | RCA Televison & Video
RCA Model # F19261
Try pressing the display button on your remote for a few seconds, should unlock it.
Jan 19, 2008 | RCA 32F531T 32" TV
DVD PLAYER
what kind of dvd player is it, is it for your home? car? and what kind of tv is it goin to? get back at me, jason
Dec 28, 2007 | Sharp 25H-M60 TV
Televison & Video Logo
Top Televison & Video Experts
