Question about Panasonic SA-HE200 Receiver
Receiver switches modes after a period of time
The receiver switches from DVD mode to VCR mode while I'm watching a DVD. Then if I try to watch a VCR tape using the receiver the reeiver switches modes after a certain period of time. I have no idea why the receiver choses to switch modes after a period of time. Can anyone help me?
The actual switching is done by an electronic microprocessor. This electronic processor is most likely faulty by now, and needs to be replaced. Repair costs for this are expensive enough that buying a new receiver might be the best logical action, as a new comparable unit might cost only slightly more than the needed repair costs for the SA HE 200. Good luck.
Posted on Jul 31, 2007
I have a Sa-ex900 amp hooked up to Television ,vcr and dvd player. When I turn the amp on and want to play the tuner , the television bleeds through. In fact TV plays through all buttons except VCR1
it seems to be ,you have a possible wrong connection..I
may I recommend you to check the connections in accordance with my model connection procedures given below and correct if something is misconnected..
I believe Your Television ,vcr and dvd player all connected to each other thru Technics Receiver itself (not directly connected to each other ) and whenever you want to listen/watch any of it ,you make a selection thru Receiver..
** in order to do this both DVD and VCR 's "2xRCA audio" and "1x RCA Video" cables for "IN" and "OUT" should go to Receiver separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected )
** Additionally your RECEIVER's prefably only "1xRCA Video Output " should go to TV to watch the video of both DVD and VCR (audio will come thru Receiver.)
Ok, now Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action to listen your TV on Receiver
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV .( every TV has different type of Audio out jacks )
** to "TV input "or "AUX input" or "Optic Cable input"
of your Receiver (whichever you want ,based on the necessary cables on your hand )
** than just switch to respective mode on
Receiver corresponding the connector you have used on the back of Receiver ..
There you go..Tv sound are on the
Receiver .
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 07, 2011 | Technics SA-EX900 Receiver
I have a one year old berenger atomic time watch that has stopped working last week. May I perhaps need to get a new battery/ What does radio controlled watch mean? Thanks
I would try replacing the battery in your watch to see if it comes back to life. So-called "atomic watches" have tiny radio receivers in them that periodically listen for the official atomic time being broadcast via WWVB in Colorado. However, as you might imagine, it takes a lot more power to operate a radio receiver than it does to power a typical quartz wristwatch, and even with larger-capacity or double batteries, it's been my experience that these watches burn through batteries more quickly than traditional "set them yourself" watches.
An additional factor is that a watch that cannot find the WWVB signal will scan for long periods of time before putting its radio receiver into hibernate mode. So, if your watch has been stored in a basement, an interior room in a large building, or some other place where a radio signal can't penetrate, that would also shorten the watch's battery life.
May 10, 2011 | Watches
I transfered from watching my sattelite tv to watching a dvd using the tv control. The dvd sound worked ok, but I couldn't get a pictue. Then I tried to watch tv again, but the vidio would not come in,...
Just in case, here's the 108-page user's manual for your TV:
http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf
Yor "NetCommand" TV remote is a wondrous thing, capable of throwing off anyone.
When the 'Device Selection Menu" is dispayed, and only when the device icon is highlighted,
does the key work, and it also only works when the remote is in "A/V Receiver" mode -
not in "CABLE or DBS" mode, nor "VCR" mode, nor "DVD" mode.
So, (1) set the NetCommand remote to "A/V Receiver" mode
(2) bring up the Device Selection Menu, using the key on the remote
(3) highlight the Satellite receiver input icon (highlighted with a Yellow outline)
(4) press GUIDE on the remote, to swap the analog digital setting.
Also displays ChannelView for Antenna 1 and Antenna 2 - you may have accidentally
set the TV to get its input from the wrong Antenna.
If your TV has lost memory of its DBS source, you may have to re-teach the TV (using the remote)
that the DBS (Digital Broadcast Satellite) input exists, and to which input its connected.
Refer to "Edit NetCommand, Add an A/V Receiver", pages 39-45 of your Owner's Manual.
Jan 31, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a vcr samsung dvd-v2000. How could i record from dish reciver dual mode model id= vip222k-hd Thank you in advance
Hi this is Luke. Here's how: 1. Put receiver on single mode. 2. Use RCA cable on tv2 out chan 21 - 69 out as output from back of vip222k. 3. Plug the other end of RCA to Video input of vcr. 4. Turn on receiver, press record. 5. And whatever you watch on TV1 will be recorded on VCR. Let me know if this help.
Jan 25, 2011 | DISH Network DISH-2800 DTV Receiver
Humming sound when watching tv,but not when watching dvd's
It wounds like you are getting interference from you tv to the receiver. You can try a few different things here.
1. Connect the tv output into another input on you receiver to see if it isnt the channel on the receiver.
2. Try a different set of cables between the tv and receiver. Faulty cables can give you problems.
3. Connect the cable from you tv to a different device. (another dvd vcr blue ray etc.) This will tell you if its the receivers or the tv.
Sep 13, 2009 | Yamaha HTR-6030 Receiver
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hk3480 buzzing
Is the buzzing coming over the speakers or just from the receiver itself?
If over the speakers:
Try swapping ports on the receiver from the DVD. Go from DVD into an auxiliary video or VCR 2 if available.
Try swapping out the cables with known good ones.
But do this in steps to be able to nail down the problem and not just leave a mystery.
If the sound is solely coming from the receiver it could be a dusty fan. Blow it out with compressed air ,With the Power Off.
Or, my favorite, might just have to crank it up so you can't hear the buzzing.
good luck
COEch
Mar 11, 2008 | Harman Kardon HK 3480 Receiver
Denon reciever
Sounds like you are exceeding the maximum power output of the receiver. Try disconnecting some speakers (and switch to A-only mode if your model has multi-zone) and see if that makes a difference.
Dec 31, 2006 | Denon AVR-2801 Receiver
Panasonic SA-HE200 Receiver Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
blanqui2000
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
