Question about Panasonic Cameras
I have a panasonic ag-800dp supercam.It has the wavy lines in the view finder that comes when the capacitors start going bad. This is aproblem that happens with this mdel camera.I have a pro camera repair tech who can fix it if he could get the proper service bulletin for repairing this problem. Any idea how i can get one.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Have you tried here for Service Manual and/or Schematics?
Good luck and Thank you for using FixYa.
Posted on Dec 06, 2008
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
Image is all pink
I have have seen this a hundred times.. you have a bad ccd... the only thing you can do is send it to panasonic ... I would ask for a estimate first because it might cost just as much to fix it as to buy a new camera... sorry :(
Nov 14, 2012 | Panasonic Lumix DMC-TZ2 Digital Camera
Colour Noise and Dim Display
Did you try cleaning the tape head of the player?
For some reason be sure all the gear or any mechanical inside the player is freely rotating.
Adjust the VCR tracking to get a good picture.
Feb 19, 2008 | Panasonic AG-1980 S-VHS VCR
How do I remove the x1 auto-hss from the electronic view finder
Hello Try Pressing The pause and display Buttions at the same time
Aug 31, 2009 | Panasonic AG-188 Camcorder
MY Hvx 200 Is totally Black when I turn it on. the display and playback of my old footage works fine but the picture is totally black. any Ideas When I switch the camera on, the view finder is totally...
You should go into the menu, camera settings and set the evf to on. EVF stands for electronic view finder. This can be set to be on when the lcd is open or closed. CAreful, if the evf is set to on and you point the viewfinder towards the sun, it will burn white marks into the viewfinder and ruin it.
May 09, 2009 | Panasonic AG-HVX200 Mini DV Digital...
Supercam ah dp800h powers on but nothing in the view finder
most likely problem is many defective capacitors on the video board.
Mar 02, 2009 | Panasonic AG-DP800H Camcorder
Time / Date Generator
try replacing the lithium battery that provides backup power to the clock.
Jan 19, 2008 | Panasonic AG-DP800H Camcorder
Lines in AG-dp800h
Hello all!!
I found the solution!!
3 electro chemical capacity in the 3700 series on the camera head board.
change the chemical rear the DAC and above the ADC for process digital signal.
The name of the capacity: c3 c6 c9 in the 3700 section on process board.
The capacity is a part of filter the reference signal out of the DAC for ADC reference for ic1 ic2 ic3...
If the capacity is dead a sinusoidal signal appear for the red blue and green reference voltage and the result is a parasit signal into all camera.
You can measure a 50khz signal on the composite video signal.
Best regards
Phil_F
Jan 13, 2008 | Panasonic AG-DP800H Camcorder
Problem Supercam AG-Dp 800heg
Hello Situ,
If you must Change the erasing head's supply filter (capaciter) then change the audio erasing Bios OSC, transformer supply filter tantlem capaciter, the problem will be clear.
Regards,
Muthu.M
myesak_14@yahoo.co.in
Jan 04, 2008 | Panasonic AG-DP800H Camcorder
Panasonic DVC 7
Clean the heads with a Panasonic MiniDV cleaning tape. I've seen many cameras come through our shop with this problem - a quick cleaning made a world of difference.
Mar 13, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Cameras Logo
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
