Question about Microwave Ovens
How do we make the touch pad control panel brighter on the Sharp R-958m /// any help would be much
  • Microwave Ovens Master
  • 9,098 Answers
One way to help a little is to remove the control unit and clean the front of the glass display and the rear of the plastic display window.
That can brighten it up if there is dust accumulation.
Always use a soft cloth (never a paper towel!) that is damp with non-ammonia cleaner.
In many cases, a weak display is due to backlight circuit trouble.
We repair those for US and Canadian customers, but in the UK you can contact Quality Electronic Repairs. I think they repair these.
Posted on Dec 07, 2008
Microwave is in Lock -- how do I unlock it?
" 1. CHILD LOCK
The Child Lock prevents unwanted oven operation
such as by small children. The oven can be set so
that the control panel is deactivated or locked. To
set, touch Custom Help, the number 1 and Start/
Touch On. Should a pad be touched, LOCK .
.. ON will appear in the display.
To cancel, touch Custom Help and Stop/Clear. "
Also, to find manuals........
Oct 03, 2014 | Sharp R-1480 Microwave Oven
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    My R-4A58 unit only displays
    The keypad control board will need to be replaced.
    Apr 26, 2012 | Sharp Microwave Ovens
    Sharp Microwave on "Lock" and
    The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
    Mar 08, 2011 | Microwave Ovens
    On the touch pad numbers 3, 6, 7 and 0 dont work
    sounds like the touch pad control has failed ... there is a touch pad on this unit and also a control board located behind units touch pad... you can gain access to this by unplugging unit and removing console that houses touch pad /clock assembly ... once removed the only test there really is to do would be with power off remove ribbon cable to touch pad and make sure clear of any dust /debri and reconnect there are 2 small holes in ribbon cable that are used when reconnected fir into small slots and firmly connect... if that doesnt fix i would recommend a new touch pad... not sure what area your located... there is a distributor for sharp in dallas ,texas called
    global micro parts... reputable company that if you give them your model number they can assist you with the part.... good luck to you
    Jan 27, 2011 | Sharp R305KS Microwave Oven
    My sharp microwave touch pad doesn't work.
    We regularly repair microwave control panel assemblies, usually for $39.95, but if your keypad is bad, it will run more.
    Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
    William E. Miller
    prototech@usa.net
    http://www.microwavedisplay.com
    Jul 08, 2010 | Sharp R-1480 Microwave Oven
    How to set the clock on my sharp carousel microwave
    Touch STOP/CLEAR pad.
    Touch TIMER/CLOCK pad.
    Enter the correct time of day by touching the numbers above in sequence.
    (for example: for 12:30, touch 1 2 3 0)
    Touch TIMER/CLOCK pad again.
    Sep 25, 2009 | Sharp Microwave Ovens
    Unable to get the touch bottom to work
    Quite often on the compact models, the solution is to pull the control panel assembly off, remove the circuit board and clean the surfaces shown in the photo with high-grade alcohol.
    That would include the back of the LCD glass and both sides of the rubber strip.
    Jan 04, 2009 | Sharp R-1480 Microwave Oven
    Microwave touch pad work light doesn't work
    We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
    This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
    Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Dec 29, 2007 | Microwave Ovens
    Microwave Ovens Logo
    47 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
