Question about Nikon COOLPIX L4 Digital Camera
The lens cover wont open
When i turn it on the lens will come out but the cover that is over the glass part of the lens wont open
  • Anonymous Jun 02, 2008
    the lense cover does not retract at all. This has never occurred before. We've tried gently brushing out the covers with a soft paint brush.
  • dkjeldsen Jul 15, 2008
    Have the same problem and the lens covers will open easily when using a manual device to open them but will not retract on their own when you turn the camera on.
    Novelist:
  • 107 Answers
If debris like sand or dirt get into the mechanism which closes that cover it will jam shut. Try gently placing something pointy in the gap between the two blades of the cover. Do not force them apart, if this is going to work they should free with very little pressure. Be very careful not to touch the lens especially if you are using something metal to separate the cover. David Millier Advance Camera Repair
Posted on Feb 24, 2007
SOURCE:
Lens cover wont open
Common problem with automatic lens covers. I use a toothpick to manually open the lens with the camera on. The use some glue, small amount on the lens cover to glue it open. Then I would carry it in a carry bag.
Nov 24, 2013 | Cannon Cameras
Tip
Welding helmet lens covered with spatter?
Is your welding helmet glass dark lens covered with spatter from welding and need replacement often? Cut a piece of 1/16" (1.5mm) clear perspex to the same size as the lens and install this in front of the dark glass. Spatter does not adhere to the perspex and the glass lens will be protected indefinitly.
on Jan 19, 2011 | Welding Tools
I have a Canon PowerShot 850IS that is about 3 years old. It has been a great camera...up to this point. Just recently I went to take some photos and the bottom half of the images are blurry. Seems odd...
Could be that the lens cover doesn't open fully or that perhaps there is a smudge on the bottom part of the lens. Maybe a water drop. IF the front optics are dirty, use an optical-quality lens cleaning solution and cloth (if you have glasses, the lens cloth that came with your glasses). Apply a very small amount of cleaner to the cloth and gently clean the lens.
If the lens cover doesn't open, could be a grain of sand. The only thing to do is to gently move the lens cover in and out & hope the sand works its way out.
Mar 02, 2011 | Canon PowerShot SD870 IS Digital Camera
Wont play DVD
I would either open up dvd tray and blow real hard inside a couple times.
Or
Remove cover of the player, take rubbing alcohol and cotton swab and wipe the glass laser lens eye with it so it is clean.
If the lens is dirty, this will surely solve your problem. If cleaning doesn't work, then the laser lens circuit could be faulty.
Dec 01, 2009 | Toshiba SD 37 VF DVD Player / VCR Combo
How do you change the lightbulb inside the oven??? I cannot get the cover off!
AROUND THE COVER THERE IS A CARBON BUILD UP CLEAN WITH OVEN CLEANER AND YOU SHOULD SEE THE SMALL SCREW HOLDING THE COVER IN REMOVE IT AND GENTLY PRISE IT OFF ..
Nov 22, 2009 | Kitchen Ranges
Wii wont read any games
remove the cover and drag a glasses cleaner cloth over the lens. if that does't work put a disk in while its still open and see if the motor is working if not you might need to buy a new motor and swap them.
Jul 31, 2009 | Nintendo Wii Console
Lens wont extend, lens error restart camera
My wife's Canon SD200 got stuck with an open lens and the E18 error. I opened the case and wiggled things and still nothing. Then, I turned the camera on and started tapping the edge of the lens casing with the magnifying glass I'd been using (need the battery and memory chip in place and make sure you've transferred pictures to your computer before trying this). Voila! The lens closed. But, of course, it wouldn't open and still gave the E18 error. Well, one good tap deserved another and Voila! again. It opened. After a few more iterations - and cleaning the lens casing each time, it was back to normal. The trick is the timing of the tapping. Just after turning on the power to the camera start tapping on the lens casing - not hard - just a light tapping. And don't tap on the glass lens itself -- you don't want to really break it.
May 15, 2009 | Canon PowerShot SD600 Digital Camera
Lens plastic cover little sheets wont open.
I need to remove front cover and look for an obstruction or possible substance spilled or splashed in camera. N/C for estimates! www.flcamerarepair.com Art Schneider (40 years exp.)
Mar 31, 2008 | Panasonic Lumix DMC-LZ5 Digital Camera
When turn it on the lens will come out but the cover that is over the glass part of the lens wont open
This is a common problem to deal with in all these type of cameras. You can take the camera apart going slowly and you will need a small philips and straight screwdriver. It is easy to do but time consuming. Once you get the lens apart you can see the spring that holds onto the side and either super glue it if the plastic is broken or remove it all together. I would rather try to fix it. Let me know how it goes.
Feb 11, 2008 | Panasonic Lumix DMC-LZ5 Digital Camera
Nikon COOLPIX L4 Digital Camera Logo
169 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
