Question about LG MU-42PM12X 42 in. HD-Ready Plasma Television
SAP - I can't get my new TV out of Mono and into stereo.
No matter what channel I am in, my tv only displays that the audio is in "mono". When attempting to change on the remote, it will not allow me to do so. It will only display mono...HELP! Thank you
    President:
  • 1,284 Answers
Are you using a cable box sush as a Comcast cable box? If so then the volume control within the cable box is most likely not high enough for the TV to detect a stereo pilot signal. The Comcast remote (if thats what you have) still is programmed to operate the volume within thier box, the volume display will be at the top of the picture and it will be in white. Turn it up until the word "stereo" appears. then leave it at that setting and use your TV's volume control only.
Posted on Feb 13, 2007
Ilo tv in spanish need english
To change the menu language of the TV using the remote:
Display the menu screen.
• Press [MENU].
6 menu items will be displayed. The third item will be ENG/ESP/FRA
Select "ENG/ESP/FRA".
• Using [CH up / CH down] buttons, select "[ENG]/ESP/FRA".
Every time you press [VOL up / VOL down] buttons, the language
will be advance to the next. Select the language. When ENG is selected, exit by pressing [MENU]
If you are trying to change the AUDIO of the TV, simply press the [AUDIO] button on the remote. This will advance the selection between MAIN, SAP and MONO. MAIN is the native language of the program (often in stereo), SAP is "secondary audio program" - which is usually a second language, but may be an audio source not related to the picture at all. MONO is monophonic, or a single sound source that is the result of combining the LEFT and RIGHT stereo channels to one output or speaker. This selection is often a downgraded version of the stereo output provided by the MAIN audio selection - but may be useful under certain conditions.
You can review your manual here. Pg. 31 has details for the menu display language selection and pg. 16 has details for audio language selection.
If you found my answer to be helpful, please rate it "very helpful" Thanks & good luck!
Aug 22, 2011 | iLO IWT3206 TV
My remote broke and some of my channels are on sap. and when i go to the menu there is no audio setting how do i put the channel setting back to stereo or mono
Hello
While receiving an MTS broadcast, press [Audio] repeatedly to to cycle through the available channel.
Main: Outputs main audio.
SAP: output secondary audio programme.
Mono: Outputs mono audio.
You must ahve remote control to change these, because only remote control have Audio button on it to control these. OK.
May 05, 2011 | Sylvania LC-155SL8P 15 in. LCD Television
Can't change from MONO to AUTO mode
Hello
Can't make sound from mono to auto is your problem I thinks and posts this solution.
Hit the "Menu" button and surf through, come to "Sound Adjust" window.
The settings allow you to change and adjust sound in your TV. There are Bass, Treble and Balance control to adjust to your individual taste.
To adjust them
1. Press Menu button.
2. Press UP or DOWN button to select the desired item.
3. Press => or 4. Press EXIT button when finished.
When adjusting the parameter of "Balance" control, always set it to mid position to get stereo sound from both speakers. If it is set to any extreme end, there will be no output from the speaker of that side, and will hear as mono.
If you press "0" [Zero] button, you can reset the sound settings to it Factory settings.
To select 'Streo mode;
1. Press "Menu" button.
2. Press UP or DOWN button to select MTS [Multi-channel Telivision Sound].
3. Press => or [The ON AIR arrowtells you if a broadcast is in stereo AND/OR contains the SAP.
Press "Exit" button when finished.
Keep the TV in stereo mode to get the best sound quality. The sound will work in stereo
mode even if a certain broadcast is in mono sound only.
Choose the mono setting to reduce excessive noise on a certain channel or broadcast.
Selecting SAP will allow you to hear an alternative soundtrack, if one is available.
Apr 01, 2011 | JVC AV32F476 32" TV
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
No sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Mar 26, 2010 | Televison & Video
Using my universal remote contol,lost sound on 2 TV channels
The solution is to change the audio input from SAP (secondary audio programming - default on TV sets sold in Canada) to Stereo or Mono. Your remote will need to be able to access the "Menu" settings screen for your television set.
May 07, 2009 | Samsung TV Remote Control
Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Feb 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Akai LCT3785TA stereo vs. mono issue
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
Sep 04, 2007 | Akai LCT3201AD 32 in. LCD Television
LG MU-42PM12X 42 in. HD-Ready Plasma Television Logo
949 people viewed this question
Computer Repairing
Computer Repairing
