Question about SanDisk Sansa m240 MP3 Player
Backlight not working
My Sansa m240 is now exactly one week old now, and the backlight stopped working. After I realized it wasn't working anymore, I went to settings, display, then to backlight, and it is set to go off in one minute. So now it is hard to see what it says and is very annoying.
  • alldogsrock Dec 06, 2008
    I took out the battery, and turned it back on. I went to settings again to see if it changed. It didn't, but realized that the backlight was working again!
    Scholar:
  • 111 Answers
This can really be a challenge since it's you are no longer able to see the display to change the setting, see if you can shine a fliash light on it so that you can at least read the display to change it. Otherwise see if you can get it to reset to factory default by either taking out the battery or just leaving it on till it is completely drained.
Hope this helps.
Posted on Dec 06, 2008
Can I replace my non backlit keyboard with a backlit one?
If it is for your exact model than that keyboard should work. The backlight function is built into the keyboard itself not the laptop. I hope that helps
Jun 12, 2012 | ASUS K50IJ-C1 Notebook
It'll turn on, the backlight will briefly flash, then it won't do anything. The menu won't come up, no music will play. It is as if it won't initialize? All I can see is the sansa in the disply
Its damaged by grounded device.
Try downloading or re-install its firmware if possible.
If not - then disposing it will be the last good option.
Jan 25, 2011 | SanDisk Sansa m240 MP3 Player
C150 as not working what's solution?
Check the orange "Hold" switch on the left side of the Sansa C150, if you cannot turn on the MP3 player or if none of the buttons is working. When the "Hold" switch is up, the buttons are disabled. Slide the "Hold" switch down to activate the buttons again.
Press and hold the "Power" button until the LCD screen lights up when turning on the MP3 player. Pressing the button quickly does not turn on the device. The "Power" button is located on the front of the device, under all the other control buttons.
Replace the AAA battery, if you cannot power on your MP3 player. To replace the battery, remove the battery cover from the back of the device by pressing in on its tab and pulling it off. Remove the old battery, insert the new battery and replace the cover. One AAA battery provides approximately 15 hours of power for your Sansa C150.
Change the backlight settings to conserve battery life. This is useful if you find the battery loses power quickly during normal use of your Sansa C150. To change the backlight settings, choose "Settings" to bring up the "Settings" menu. Select "Display," "Backlight" and then a shorter backlight time. The backlight will shut off after a period of inactivity that matches your backlight setting.
5
Review your music purchases to understand what rights you've purchased to the content, if you are unable to play a track back on your Sansa C150. When you purchase music, it comes with certain rules for how you can store and play it. You may not have paid for the right to transfer the song to a portable media player.
6
Reset the Sansa C150 if it acts erratically or if you have other problems. To reset the device, open the "Settings" menu and choose "Reset All." Choose "Save" to finish restoring the MP3 player to its factory default settings. If you decide not to reset the device during this process, select "Cancel" instead of "Save."
~KenjiFox
Jan 07, 2011 | SanDisk Sansa c150 MP3 Player
Screen does not light up
try changing the battery also try going to the menu, going to settings, then go to display and go to backlight change it and press the center button twice
Dec 30, 2009 | SanDisk Sansa m240 MP3 Player
My sansa clip will play music but the screen will not light up;
There's a timer for the display backlight that can be set and used for
saving power. When leaving the player untouched for a certain time, the backlight switches off. Touching any button will turn on the backlight, restarting the timer.
To set the backlight timer on the Sansa Clip,
execute the following steps:
1. Press Menu button to return to the Main Menu.
2. Move to Settings and select it.
3. Select Display.
4. Select Backlight.
5. Press |<< or >>| button to select desired backlight timer.
Dec 24, 2009 | SanDisk Sansa Clip MP3 Player
How do i get the backlight to go on again on my m240 sansa scandisk? thanks
On my C100 the backlight comes backon when I press the menu button.
Hope that helps.
Honestly.
Dec 01, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
TREO 90 Backlight
The Treo 90 had a problem with backlight failure, which Handspring acknowledged and began fixing back in 2002.  However, their guideline was that if your 90 did not fail within 6 weeks of use, it did not have the defective part responsible for the failure.
Your backlight probably has just died of old age.  It is EXTREMELY difficult to replace just the backlight (I've tried).  If you search long enough on eBay, though, you can probably find a 90 with a broken case, dead battery, broken motherboard, or some other ailment, but with a functioning screen/keyboard assembly, including backlight.  It's a pretty simple matter to replace the screen/keyboard assembly (there's a screw hidden under the battery that holds it into the front frame).
May 15, 2008 | Handspring Treo 90 Handheld
Backlight problems
If its less than 1 year old, have it replaced. Otherwise, you may want to find someone electronically inclined to replace the internal led light. Best of Luck.
Sep 12, 2007 | SanDisk Sansa m240 MP3 Player
Volume control stopped working
Take the warranty and the MP3 and go to the shop from where you bought. They will repair for you.
Sep 02, 2007 | SanDisk Sansa m240 MP3 Player
Backlight wont work?
Check the backlight settings in the menu - yes, cracked screen would definitely cause such a problem
May 30, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
56 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
