Question about Radio Communications
Cannot use microphone.
Whenever i try to talk with the microphone, it only plays static so others can't hear me what-so-ever.
It was working earlier on today, just fine! but now its not working at all.
I can still use the headset to listen via the headphones, but the microphone doesn't work.
(If you tap the microphone though, you can tell that you're tapping it as there is a difference in static noise.)
Thank you very much!
  • 1 more comment
  • msong17 Jan 20, 2009
    same issue
  • askjimbo Jan 25, 2009
    I have it to
  • nicewood Mar 17, 2009
    Same here :[ can't record and talk at the same time, because of static :[
    Scholar:
  • 111 Answers
Hi I have had a similar problem with a Mic, too things to try , first try it on a different appliance to rule out the appliance you are using, if it still doesn't work then it's most likely a short somewhere, tough to repair but worth a shot if you have the patience.
Hope this helps.
Posted on Dec 06, 2008
Lg motion 4g "audio problem" with microphone
I have s lg motion and whenever i try play a game where i have to talk into the microphone it says it doesnt work...
Aug 01, 2013 | LG Motion 4G for MetroPCS with new service...
People can hear background noises on my PC but not my voice
Perform some simple steps as follows.
1. Double click on the volume control icon in the system tray, that is on the right hand bottom side of the screen. Check if the microphone is muted.
2. Right click on the same icon, and select "adjust audio properties." You will now get a window that says Sounds and Audio Devices Properties. Click on the tab named voice on top of that window, and check what is selected as the voice recording device. Check in the drop down menu to change the device and use the "test hardware" option to test the mic.
3. Make sure your microphone is working fine. Other people are not hearing your music from your microphone, but from your system itself.
Get back if you have additional questions.
Jun 15, 2009 | Logitech 250 Headset
When I speak it's all static
Get another headset,,,,its ur mic....I should noe,,,i play cs a lot,,,,,I usually go through some headsets,,haha
Jun 14, 2009 | Logitech Stereo 350 Headset
Audio - microphone problem(Other users cant hear me)
Maybe its not you that got the problem, but the other user.
Apr 11, 2009 | Acer Extensa 4620 Notebook
Static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Sound
Normal 0 The problem is that your microphone is picking up feedback from your speakers when you talk because the speaker volume turned up. Try lowering the volume. If this doesn't work I suggest you use a set of headphones and it will eliminate this problem completely.
Hope this helps. Bud
Jul 02, 2008 | Microsoft LifeCam VX-3000 Web Camera
Recorded Video Plays back static
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
May 15, 2008 | Logitech QuickCam Communicate STX Personal...
Headset
There may be a few things that are wrong:
1. Your headset may be faulty.
2. You may need to configure your router.
First, make your IP address static.
If you do not know how to do this, then there is a guide here.
After that, you will need to go into your Router's Control Panel.
You can do this one of two ways:
1. Go to Start --> Run. Type in "cmd".
Once the command box opens, type in: "ipconfig /all"
Find the "Default Gateway" and paste it into your browser.
You will be prompted for a username and password, which you would have set when you installed the router.
2. Go to http://whatismyip.org and find out what your external IP address is. Copy the address, and paste it into your browser.
Once you have logged into your Router's control panel, look for "Port Forwarding" or "DMZ".
When you get onto the page, add a new record.
Use the static IP address you used earlier, and set the record to "DMZ".
[[DMZ open ALL ports on that IP address, allowing incomming and outgoing traffic to pass in and out of the computer]]
This should allow the headset to work, however if it doesn't, it may be faulty.
Jan 08, 2008 | Sony PlayStation Portable (PSP) Console
Loud static
Verify that your microphone is configured correctly loadTOCNode(2, 'resolution'); 1. In Windows Live Messenger, if you cannot see the menu, click Show Menu. 2. On the Tools menu, click Audio and Video Setup. 3. Click Next two times. On the Microphone page, verify that the correct microphone is selected on the Select the microphone you would like to use drop-down list. Speak in a typical tone of voice, and then verify that the voice meter moves up and down correctly. 4. Click Next, and then click Finish.uparrow.gifBack to the top
Verify that your contact's speakers are working correctly loadTOCNode(2, 'resolution'); To do this, have your contact follow these steps: 1. In Windows Live Messenger, if you cannot see the menu, click Show Menu. 2. On the Tools menu, click Audio and Video Setup. 3. Click Next. On the Speakers page, verify that the correct sound system is selected on the Select the speakers or headset you would like to use drop-down list. 4. Click Play Sound, and then verify that you hear the sounds correctly. 5. Click Stop Sound. 6. Click Next two times, and then click Finish.
Jan 02, 2008 | Microsoft LifeCam VX-3000 Web Camera
Radio Communications Logo
928 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
