Question about Powerware 9120 UPS System
Powerware 9120 DC Bus Fault Problem.
I have a Powerware 9120 that shows 'DC BUS FAULT' error on screen. What causes this error? How can this be repaired? Unit is out of warranty,
  • 6 more comments
  • Anonymous Nov 07, 2007
    I got the same problem "DC Bus Fault"
  • katy martinez Feb 07, 2008
  • asenk2006 Jun 23, 2008
    What causes this error? How can this be repaired?thanks
  • Agosu Segun Aug 05, 2008
    WHAT CAN CAUSE THE FAULT AND WHAT CAN BE DONE TO REPAIR IT WHEN IT DISPLAYS DC BUS FAULT
  • kapekele Sep 08, 2008
    It is just te same problem, display of DC Bus Fualt on the LCD and the protected units went off.
    Email me, please.
  • fxtommy May 14, 2009
    bypass not avail
  • ghdshgsd May 11, 2010
    thanks!! fixed my problem too.......
    change the 2200uF and the 100uF
  • damonms May 11, 2010
    I had one with the same issue, I replaced the 2 caps and it worked great for a while and now it is down again with the same error message. Now I have a couple of them with the error. Is there fix beyond the 2 caps ?
    New Friend:
  • 25 Answers
There is a 100uf/63v capacitor near the IRF630 fet. You need to replace this in order to fix this error. Along there is also a 2200uf/16v capacitor. It is a good idea to change the both at the same time.
Posted on Feb 05, 2008
  • 2 more comments
  • martinc996 Sep 04, 2013
    Hi Vassilis,
  • Iannis Manousakas Sep 13, 2013
    Hi Vassili I can't locate the capasitors Can u post a photo of the circuit board of 9120 6kva
  • Vassilis Chamaidis Sep 20, 2013
    Iannis. This fix is for the 700va model. For now i have no solution regarding the 6kva model.
  • Starseven Ops-tran
    Starseven Ops-tran Apr 19, 2017
    i encountered the same problem dc bus fault in liebert gxt can u give me a solution for this?
Hey bham_athens you are the man... The solution you provided is right in the spot. Atleast for me it worked flawlessly. Thank you very much !!!
Posted on Mar 01, 2008
  • Mohammad Ayaz Jun 11, 2011
    What solution Mr.bham_athens had suggested for rectification of the problem?
  • Wisam Mustafa Jun 11, 2018
    I have 3 liebert ups GXT2 appear DC bus fault ,please help me to solve this problem ,when i turn on the ups its appear this fault...
    Problem Solver:
  • 3 Answers
On the big heat sink there is an insulated gate bipolar transistor G4PF50W near the rectifier , remove it and measure it using a digital multimeter. If it is open i.e it cannot read anything then replace it. Also make sure that the rectifier is ok.
Posted on May 27, 2009
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Pleace change the three 100uf/50v as indicated in the image attached and the 47uf/400v by the side of K2608 wise you all the best.The name is Ansah of IPMC.
Posted on Feb 13, 2015
  • Adrin Freisinger
    Adrin Freisinger Apr 19, 2016
    Hi Ansah, where is the attached image, please ? Thanks
  • varvarjusha
    varvarjusha Dec 18, 2018
    hi. in my 2pcs 47uf/400v, was ok but 100uf/50v was with big ESR and changing was helped, thanks a lot
Dc bus fault error occurs when booster section is not working, try to replace booster section igbt & associated gate drive circuit of psdr card
Posted on Oct 16, 2011
DC Bus Fault error can't be repaired by replacing the batteries. It is a board problem. Most of the transistors on the board are toasted. I tried to repair this with no avail. I need a diagram of its board to repair it.
Posted on Jan 17, 2008
    Scholar:
  • 168 Answers
Try to change the battery inside with a new one. good luck!
Posted on Feb 13, 2007
I think you have to change the PSDR board inside the UPS.
sayan
Posted on Mar 13, 2009
    New Friend:
My UPS- Lever EM15 15kVA- shows " VDC BUS MEASURES ERROR" on screen. What causes this error? How can this be repaired?
Powerware 9120 DC Bus Fault Problem. - c6da7720-8d4b-4631-862e-3fa465b989dd.jpg
Posted on Jan 21, 2017
  • 2,005 Answers
Allways something to remember if replace parts i will give a little hint to this emergency devices if there is a capacitor rolling neccesary to give it an extra long time to live is in this kind of error to think first to measure the flow again which is on the capacitors and how much tolerance is left with respect to the value usually tight chosen by the manufacturer financially gain so that it breaks down faster (from Korea manufactured capacitors effect I call it), if for example, you will find a 10 volt capacitor and there is 9 volts, put your nowadays usually easy good nichicon, rubycon or elna 16 v or even 25 volt type in place so that you have a power reserve and that the life also significantly improves the capacitor cups are now small course, to see if it fits in place for a minimum always 6 volts higher than the selected type capacitor.
Posted on Sep 28, 2016
It is both condenser 3300 mf 450 V that it is necessary to change
Posted on Jun 14, 2009
SOURCE:
What cause dc bus fault on 9120 power ware ups?
why don't you check the DC bank capacitors, you may need to replace them
Apr 04, 2015 | Powerware 9120 UPS System
DC Bus Fault Error
Dc bus error is from charger o maybe inverter
Mar 24, 2015 | Eaton Powerware® 9120 UPS System
Pw9120-700i dc bus fault ,low o/p v messages
If your batteries are ok a DC BUS fault and low o/p voltage means one of the componants inside is defective. An end user can not effect repair. You need to have it looked at.
Jul 14, 2014 | Powerware 9120 UPS System
Dc bus fault error
Check to make sure your connections are correct and tight.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Aug 23, 2013 | Powerware 9120 UPS System
Troubleshooting of "DC BUS Fault"
its busted by the sounds of it so unless you add more detail thats all I will give as an answer
Dec 06, 2011 | Powerware 9120 UPS System
DC Bus Fault in Powerware 9120 6KVA
Honestly, the cost of repair might exceed the cost of a new unit. We can likely get any parts needed to repair the unit, but might not be the most cost effective solution. Might want to price around for a replacement unit. If you need additional assitance, please contact us.
http://www.gowithon.com
Jun 27, 2009 | Powerware 9120 UPS System
My ups has is faulty i need a circuit diagram to fix it
I had a DC bus fault error displayed.
So I unplugged battery, then turned on UPS. It said Batt disconnected of course.
So when I plugged in the batt while the UPS was on, and held the power button for a few sec, the UPS displayed Batt testing.
After a few moments it was back online and had no faults!
Worth a shot.
May 20, 2009 | Powerware 9120 UPS System
Help - I have the same Fault!
Normally DC BUS FAULT is fixed by replacing C14 and C10. C14 is the 100uf/63V and C10 is 2200uf/16V. They are located between the heat dissipator and the logic board near transformer TX1.
Mar 12, 2008 | Powerware 9120 UPS System
Powerware 9120 UPS System Logo
12,377 people viewed this question
Top Powerware Computers & Internet Experts
Marvin
Marvin
geekyshrink
geekyshrink
Level 1 Expert
B.Th. Pluijm
B.Th. Pluijm
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
