Question about Bemis Cool Mist SpaceSaver 160-826-800 Humidifier
Bemis 821 000 filled with h2o but still says refill
Just filled my Bemis, it's been stored in our garage all summer.
I have a new filter in it, filled it, and it still says: refill.
What do I need to do?
I had the unit unplugged when we refilled the container.
thanks
We threw it out
Posted on Jan 28, 2009
Fan won't run. New filter and wick. Why won't the fan come on?
work switch back and forth a few times . sometimes they seem to gum up over summer
Feb 06, 2015 | Humidifiers
I have Bemis (Esswick) Humidifier Model # 4968. The motor runs fines however I can't get the humidity in my above 30%. I changed the filter and it was close to 45% for a few days but running continuously,...
You should be able to get a higher humidity rate at normal settings. If you want high humidity above 40% that should be easily done with the high speed operation. The unit may need a good internal cleaning, and use a Vinegar solution to clear any Calcium or other mineral deposits from the misting ports and misting elements. You must use only Distilled or Filtered water, not tap water.
Jan 29, 2018 | KwikFilters.com Bemis 4968 Humidifier Wick...
My unit has a new filter, all parts seem to be in place, it has filled with water. It does not turn on no matter how high I turn the humidistat.
is the water fill rod in place with float attached, and the opposit end in the switch hole? does the humidistat clik on and off when turned (just clik) put your finger or a pencil in the hole on the underside and try again. its prolly the float poor design...
Oct 28, 2010 | Bemis H12 300 Humidifier
Water not flowing from bottles...
The water containers have a small exit valve that fits into the mist head compartment. Should particles (Lime or Calcium) collect within the valve; no water will exit. Check the reservoir outlet and use Vinegar solution for cleaning parts. Use Distilled or Filtered water ONLY.
Feb 05, 2018 | Bemis 427 300 Humidifier
Not enough humidity
thanks for your question,
seems to me you have a calcium build up inside the unit, something has slowed down the humidification process and that would be the most likely cause, you should run some diluted (CLR) through it and this should take care of the build up, leave it set for a while with the diluted solution in it then drain it out, and refill, give that a try and it should help, also check to make sure the fan is not getting cloged with dust and clean that too, thanks again for your question, please let us know how we did,
mr.grzz
Jan 22, 2009 | Bemis 427 300 Humidifier
Fill level & digital readout (bemis humidifier)
There is a sticker that comes in the owner's manual that apparently falls out frequently. I was told that the fill level is two inches below the top edge of the reservoir. I am going to mark mine with a Sharpie since stickers have a tendency to fall of when wet.
Jan 05, 2009 | Bemis Whole House Digital Humidifier ED11...
Moisture not coming out
i realize this answer is a year old; but, i would guess you didn't let the wick become saturated before running. fill the resevoir with water, then let the humidifier sit idle while the wick is saturating. when it is completely saturated, the refill light will go off. refill the resevoir with additional water, as needed. then you can run the humidifier.
Jan 20, 2008 | Bemis Whole House Digital Humidifier ED11...
Fan runs but no change in the humidity. I can run the fan at the highest setting and go a week or longer with out refilling the water jugs
I have same problem. Water does not come out of the bottles. One bottle empties first. the valve at bottom may be too tight. I loosened the left bottle cap and that released enough water to fill the tray and get to the wick element. I don't know why or how it knows one bottle is empty and changes over to the other, or how it only meters out enough water to fill the tray since there is no moving parts.
Jan 14, 2008 | Bemis 427 300 Humidifier
Bemis Cool Mist SpaceSaver 160-826-800 Humidifier Logo
123 people viewed this question
Top Bemis Humidifiers Experts
Tom Chichester
Dayton Computer
Dayton Computer
Are you a Bemis Humidifier Expert? Answer questions, earn points and help others
