Question about Microwave Ovens
Everything on my microwave works except it stopped heating food
  • Reitel Dec 06, 2008
    It only worked sporadically and then quit heating completely but goes through all the process like it is heating.
I found this on another blog and it worked for me.
Model #KB6024MK, this is a Sharp microwave drawer that would open and close properly, but when started would not heat. These drawer units will sometimes close properly, but not enough to actuate the interlock switches to power the magnetron. A quick test is to turn the unit on and press in on the drawer handle while it is running. If you start hearing the low hum of the magnetron, the interlock assembly is out of adjustment. Removed the left side panel and gained access to the switch mounts to do a quick adjustment so when the drawer closes, the switches close properly to allow operation. It may take more than one adjustment to make it work properly so test it several times before reinstalling the side panel. It should work properly when the drawer auto closes and should not require any manual manipulation from the user.
Posted on Dec 06, 2008
oscarn
  • 110 Answers
SOURCE: The Microwave stopped heating
Probably magnetron failure- needs to go back to the dealers, this is a major job, may be cheaper to replace the oven
Posted on Sep 21, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: Microwave won't heat food.
This would be under warranty, so Maytag should take care of it for you: http://maytag.com/support/index.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
Posted on Nov 09, 2008
  • 8404 Answers
SOURCE: Microwave stopped heating up the food. Everything
Check the door safety interlock switches. Remove the cover to find these small micro switches on the side away from the hinges.
Need more help ... post a comment here
thanks for using FixYa.com
Posted on Nov 02, 2009
  • 1531 Answers
SOURCE: Everything is working fine on the microwave,
this a problem with your magnetron.some units have a five to ten year warranty.they need to be replaced by a service tech
Posted on Feb 23, 2010
GE microwave model JVM1750DM does everything except heat food. Worked this morning fine.
Chances are the magnetron has failed, "heats food" the other possibility is the high voltage capacitor and diode. Repairs will approach the cost of a new microwave oven.
Apr 19, 2011 | GE JVM1750DM Microwave Oven
It does everything except heatinig up food. Model # JVM 3660 SD 001
The magnetron is not working. This open it and check to see if it has a blown fuse. Some microwave would have seperate fuse for the heating power. If fuse is good. You may be able to get a used magnetron from another microwave. Somtimes pawn shops would sell microwave for 5 or ten dollars just because it doesnt have a turnplate inside.
Jul 07, 2010 | General Electric Microwave Oven
Microwave stopped heating up the food. Everything works except for the heating mechanism.
Nov 02, 2009 | Frigidaire PLMV169DC Microwave Oven
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Microwave is not heating food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fs
Mar 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Aug 17, 2007 | Samsung SMH7159 Microwave Oven
Microwave Ovens Logo
472 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
