Question about HP Photosmart C3180 All-In-One InkJet Printer
Printers keeps trying to install
Everytime I open my computor and want to print . The printer goes through trying to install it again
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    If you are running under XP .. Do you have service pack 3 installed yet?
    Guru:
  • 731 Answers
Hi
Its nothing but a Window installer issue, the pop up window appears to install the printer.This can be easily resolved.We need to download and install Windows Installer Cleanup Utility and remove the HP programs from it.
1.Click on the link below to download Windows Installer Cleanup Utility.
http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
2.Install it and then restart the PC.
3.Click start - >All programs-->Windows install cleanup utility.
4.Look for any thing referring to HP Photosmart printer and remove it.You will get a warning message, never mind it.
5.Once its done , reboot the PC and try printing.
Revert back if there is any problem
Thanks
Rizwan
rizwan84tx@gmail.com
Posted on Dec 07, 2008
I took the same cartridge had it refilled put it back in the printer keeps saying troubleshooting print cartridge what do do
when u put in a refilled cartage the reset will not engage ,so it will always read out of ink, check printer, etc.reset you printer manually everytime u print is the only thing u can do or buy brand new ink.and install new ink then remove this will let u print once,u will have to do this every time try xing out of prompt several times on youre computer if u r printing through it and that will work,but if u r printing on straight printer u half to reset it every time. hope this helps.
Jan 04, 2015 | HP J4680 Office Jet All-In-One Printer
Paper jammed everytime. Open back door, remove paper, but next atempts with the same result, paper jammed again
First try to clean the paper roller,pull the tray,the roller is under the printer.Try to clean with alcohol.If the problem persist try to clean the band the print head that goes, open the cover and clean the scanner strip that was not dirty.If i have been useful please give me a vote :).
Mar 28, 2011 | Brother MFC-6890CDW Printer
DOES ANYONE KNOWS HOW TO SOLVE MY PROBLEM?HERE IT IS..IT ALWAYS OFFLINE MY PRINTER EVERYTIME i print it,he goes offline and the print is unabale to print can anyone help me?to fix..thank you. im using HP...
when you hook up your printer to your pc via USB...can the computer detect your printer? does it prompt out any msg such as new device is installed and ready to use or did it ask you to install the printer driver?
if your pc can't detect your printer, replace the USB cable and try again.. and try to plug into a different USB port on your pc.. and if all fails, then most probably your printer main board is faulty...
May 28, 2010 | HP DeskJet F380 All-In-One Printer
Error message - appropriate print head not installed - what do i do
Pixma MP760 error is showing on printer: The type of print head is not correct. Install the correct print head. I unplugged the printer for a few minutes. Didn't help. The same error window shows up when I try to print from computor. When I open the printer to look at the cartridges they do not come out to the middle.
Jan 04, 2010 | Canon Office Equipment & Supplies
Canon 4150 wont print , goes into queue
Have you gone into the queue and deleted the print jobs and started again? Do you have any error lights? If so there could be a hardware problem with the printer.
Try taking out the toner and putting it back in. Sometimes that will force the printer to reset intself.
If that doesn't help then you may have to delete the printer from the system and re-install it.
Apr 13, 2009 | Computers & Internet
Paper keeps feeding through and won't stop
Two possibilities;
One you have a messed up print job trying to print and when you turn the printer on the job just starts over.
Two the clutch that stops the pick roller is bad and the roller just keeps turning.
Unplug the machine from the computer and turn it off unplug power for awhile turn it back on not connected to the computer. If condition remains it is the clutch.
If condition goes away delete print jobs and re connect printer.
Hope this helps
Mar 26, 2009 | HP LaserJet 1300 Printer
Spooler sub system app??
The issue occurs because of a corrupted printer driver installed and because of the Vista OS that keeps updating.
-Open up c:\windows\system32\spool\PRINTERS
-Delete the contents of the directory (not the directory).
-Restart the print spool service. (service.msc)
Jul 08, 2008 | Datacard SP55 Printer
Lexmark X2350 printer problem
Usually the light blinks if you have started a print job and run out of paper...it's trying to get your attention to insert more paper before it can continue. Check and see whether there are any print jobs that weren't able to conclude and delete them. Go to 1) Start, 2) Control Panel, 3) Printers and Other Hardware, 4) View Installed Printers, 5) Lexmark 2300 Series. When you double click on the Lexmark Printer Symbol, it will open up a smaller window which will show you whether there are any print jobs that are waiting to print. If there are any, delete them. Hopefully this will solve your problem.
May 08, 2008 | Lexmark X2350 All-In-One InkJet Printer
USB not online?
u first uninstall driver,after installing restart the computer after that connect the printer again,n see does it informs that new hardware found n shows the printer name on the screen,if yes then insatll the driver again
Jan 14, 2008 | Samsung ML 2010 Laser Printer
Uninstalling
Start,Control panel,Printers and faxs,your printers icon, box ie print que for printer on the pc, should open, click on doc icon and delete it.
Should be able to double click lexmark icon to open too.
Better off using uninstall utility in windows for removing programs
Dec 24, 2007 | Lexmark X5150 All-In-One InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
1,258 people viewed this question
Ben Johnson
