Question about Sony VGNFZ220E/B VAIO FZ Series Notebook
I have a sony vaio vgn-nr110E and whenever i connect to a wireless network i have a problem with it. if i connect to a network that is unsecured (or does not require a password) it connects to it right away and lets me use the internet, however if i connect to a network that is secured (or requires a password even though i put in the right password) it connects to it but local only it says on the status and it wont let me go on the internet can you help?
  • 24 Answers
Your connection required more than a password. You need to configure your connection such as WEP, WPA or other security capabilities. To do this you need to know the wireless routers configuration and match it.
Posted on Dec 06, 2008
How to remove hard drive from Sony Vaio Laptop VGN - NR110E?
On the bottom of the laptop there should be a cover for a quare or rectangle shaped slot, most likely with two screws in it. Unscrew these, and the hard drive bay will come loose. Just unscrew it from the bay and it should be free.
May 02, 2011 | Sony Vaio VGN-NR110E/S Notebook
I have a sony vaio VGN-NR110E and itsmouse oad it not working properly..I have to press it hard for it to click.The left click is almost dead & the right one in on the edge on spoiling..please help
The warranty may cover it if it is still valid. If not then you will have to by a external mouse, they are cheap and no hassle to carry with the laptop.
Mar 02, 2011 | Sony Vaio VGN-NR110E/S Notebook
This Vaio VGN-NR110E has DVD drive trouble. Disgusted with all the fatware packaged along with the Restore DVD, I used a 'plain' copy of Vista from a Dell desktop to wipe the HD and reinstall. Everything...
you will need to reinstall the drivers for the Sony Vaio once again so that the DVD drive is detected and set.
So please check for drivers for Sony Vaio from this link:
www.esupport.sony.com/US/perl/swu-list.pl????mdl=VGNNR110ES&???SelectOS=49
Sep 26, 2010 | Sony Vaio VGN-NR110E/S Notebook
SONY VAIO VGN-NR11S SERVICE MANUAL require to replace the casing
as far as i know. they only replace casing/housing thru their repair center
but just to make sure, you can call their parts center department
1-800-488-SONY (7669)
sony.parts.com
Mar 13, 2010 | Sony Vaio VGN-NR110E/S Notebook
Wireless Lan will not turn on? The switch is on but the light does not turn on and my wireless connection does not work?
Have you installed the drivers for your adapter?
Next,be sure your router has wireless activated.Can be done on the routers home page.
You will need to enter your routers wireless security code or wep code into your laptop adaptor configuration.
Jan 17, 2010 | Sony Vaio VGN-NR110E/S Notebook
Touchpad of VGN-NR110E
1. Please click "Run", type "devmgmt.msc" and press the Enter Key.
2. In the Device Manager window, please click the "Mice and the other Pointing Devices".
3. Right click the "Alps Pointing Device" and select the option "Disable".
This should disable it.
You can also disable the Touchpad using "VAIO Control Center" Software. If the VAIO Control Center is not installed in the Computer, please download and install it from this link.
Dec 16, 2009 | Sony Vaio VGN-NR110E/S Notebook
I have a Sony Vaio VGN-Nr110E and the right mouse button will not depress. Also, I am tired of windows Vista, but whenever I go to downgrade to XP it will not let me... kind of a double wammy question...
Click Start
Click Control Panel
Click Mouse
Check to see if the RIGHT button is enabled and mapped to a function.
If your computer is "designed for Vista", your experience with installing XP will be unsatisfactory -- drivers for audio/video/networking will be unavailable.
Anyway, backup your files to an external hard-drive.
insert the Windows XP CD, and "cancel" any "auto-run" things.
Shutdown.
Restart, and force the computer to boot from the CD.
As it boots, you will be able to install XP, no matter what is currently on the hard-drive.
Nov 01, 2009 | Sony Vaio VGN-NR110E/S Notebook
Hi, I am looking for better battery for my sony
Hello there if you get a battery make sure that it is
a Lithium ion type battery they give the best run time
and it takes less time to charge the life time is also longer
best regards michael
Sep 23, 2009 | Sony Vaio VGN-NR110E/S Notebook
How to make use of the wifi to get connected to the internet ? My sony Vaio vgn-fw21l has intergrated wirelessLAN Type802.11a/b/g/draft n
You need to have your own wireless router or basically your computer needs to see a wireless signal (any unsecured or secured network around the area). For XP computers, you can go to the control panel and look for network connection and then look for wireless network connection. Right click the wireless network connection and click on view available wireless network. If your wireless card has its own utility, you may have to use it. For VISTA, go to the control panel and click on network and sharing center, click on the manage network connections options at the left hand side and then right click the wireless network connection and click on view available wireless network. If the wireless network that you are trying to connect to is secured. You may have to enter the wireless network password for you to be able to get online.
Feb 25, 2009 | Computers & Internet
Wireless network connection
you may need to run the network wizard, as your sony may not be set up as using a gateway type connection and may be instructing other pcs to connect via itself and not on the network.
Jul 31, 2007 | Sony VAIO VGN-SZ340 Notebook
Sony VGNFZ220E/B VAIO FZ Series Notebook Logo
177 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
