Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Gap setting poulan wildthing blower
Trying to fix blower need gap setting. also wont start found out that the head bolts might be loose?
Buy an echo or a stihl... poulan rates this motor for 40 hours of use and then it is done.
head bolts came loose on mine piston slap wore out jug ring and piston. don't want to spend 40d on parts to repair a 100d unit
Posted on Nov 16, 2009
  • 163 Answers
You can use an index card or a manila envelope to set the gap
Posted on Dec 08, 2008
Poulan blower PPB430V will not start. New coil(set at 10) new carb kit. new plug. (plug wet when cranking) unhook kill switch, get good spark,check head bolts, Yet, Blower will not start,not even make an...
The plug gets wet and the unit has good spark? That only leaves you with two things....fuel and compression.
Dump it just be safe and mix up a batch of totally fresh fuel! You might even put a small amount of system cleaner into it to chase of water and remove gums and varnish too. Hey...if the rings are stuck it might even free them up! Kudos on checking the head bolts....they do often get loose and drop compression enough to prevent starting. Now that you have the head bolts ruled out check compression with a guage and see if you have 80-90 psi compression. Be safe and good luck!
Jul 01, 2014 | Poulan Garden
We have had our poulan leaf blower 7 moths and its been worked on 2 xs and its not starting now and has only ran one time since then im not happy with this and i wont buy another one because it is our...
Some of these small blowers end up with loose cylinder heads! If you can wiggle the spark plug and the whole head moves this may be your problem. When the cylinder is loose it wont move fuel properly into the combustion chamber because it moves up and down a little with the piston. If you want to be able to tighten the cylinder head yourself you need to make a couple holes around the spark plug opening so you can put a 3/16th hex key on the head bolts and tighten them.
The location varys but I usually see them when I make 1/2 inch holes in the cover at the 8 oclock and 2 oclock positions about an inch and a half from the spark plug. If you get the first hole wrong you can just drill another one in the adjacent corner *(its a 50/50 chance you put the hole over the bolts on the first try!) I have blowers that need a tighten every couple months and they run just fine! Check it out! Good luck and be careful!
Sep 29, 2013 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan 18" wildthing chainsaw wont start
have you tried spraying Starter fluid into the Carb to see if it will at least try to run and verify you have good spark?
Dec 05, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need the gap for a 35cc poulan wildthing 1999
Hi h57477...
Set your gap at .28 to .32
Bud
Sep 27, 2012 | Tools & Hardware - Others
Poulan 18" wildthing chainsaw (model
This could be a couple of things, if the fuel tank brather is blocke the tank will vacume, to test this try slackening off the fuel cap when the saw starts to die, if it picks up again it is a fuel tank braether issue, the other possibility is a bad ignition unit breaking down, the only test for this is to replace the unit and try again.
Sep 19, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My craftsman leaf blower wont start
HI THE FIRST THING TO DO IS REMOVE LEAD OFF SPARK PLUG TOP THEN REMOVE SPARK PLUG ITSELF YOU WILL NEED A SPARK PLUG REMOVER OR A SOCKET TO DO THIS AFTER REMOVING THE SPARK PLUG CLEAN OFF EXCESS OIL BY DIPPING IN CLEAN PETROLAND CLEANING WITH TOOTHBRUSH LET DRY THEN WITH A FOLDED PIECE OF WET AND DRY SANDPAPER GENTLY RUB BETWEEN THE SMALL GAP AT END OF SPARKPLUG THEN REPACE SPARKPLUG AND IN MOST CASES IT SHOULD START FIRST GO BESTALUCK GLENN
Nov 13, 2008 | Craftsman 4 Cycle Blower/Vac
Stubborn Gas Blower
hey buddy chk that the cylinder head is loose or the gasket is blown,, thats what i found on mine after buying a new blower,, returned it no problem tho ,, you will have to manufacture a tool to tighten one of the bolts and also use locktite on the bolts so they wont backout after running ,, be sure to clean the holes and the bolts before applying locktite,, hope this helps ,,
bobby allison germantown tn
Oct 03, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
691 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Dwain Pippen
Roland W VanLue
Roland W VanLue
Are you a Poulan Garden Expert? Answer questions, earn points and help others
